Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
5 gear or dd7
Old 08-12-2015, 10:37 AM
Mikeron1's Avatar
Mikeron1
Mikeron1 is offline
Default 5 gear or dd7
Hello , I'm new to the forum.. I have an 06 road glide with a SE96" .. I blew that motor to pieces a few weeks back "cam bearing" which Intail destroyed the rest of the motor ... I am now having a 120" built ... I always Found myself looking for another gear with the 96" ... My ? Is change to a 6 gear or go with a dd7 ??? Pros and cons ?? Any help would be great ... Thanks Mike
Old 08-12-2015, 12:40 PM
dfwhockey17's Avatar
dfwhockey17
dfwhockey17 is offline
According to the Baker website, the DD& is for 2007 and later bikes....If you decide on a 6 speed get the OD6 versus the DD6 as the DD6 is not meant to handle over 120lb/ft of torque which i assume you will be eclipsing with your build...
Old 08-13-2015, 10:38 AM
djl's Avatar
djl
djl is offline
Received 2,061 Likes on 1,518 Posts
Five speed with the Twist Gear kit or if money is no object, the Jim's Fat Five.
Old 09-03-2015, 06:11 PM
Mikeron1's Avatar
Mikeron1
Mikeron1 is offline
Default Motor size
I guess I went in a little blind on this motor build .. What would be an average cost for someone to have a 120" custom built ,installed and get my bike back ????? It started out around 10k but quickly jumped to 13-14 k and the job is not done or even started for all I know ??? Just looking for some thoughts ... Thanks
Old 09-03-2015, 07:32 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
You're probably being overcharged. A new 120" is $5700
Old 09-05-2015, 11:05 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,891 Likes on 3,350 Posts
Baker OD6......(or an oem builders kit if they make one) forget about Ultima or anyone else's for that matter. I only have 2,000 miles on my Ultima and i had to tear it apart already. cheap inferior parts.....
Old 09-06-2015, 05:19 AM
Next In Line's Avatar
Next In Line
Next In Line is offline
If your bike was stock (not including the motor), then you are going to need a better clutch, ecm, bigger exhaust, throttle body & injectors, air filter, etc.
Before they start the work, ask for a detailed list of all the parts and labor required.
Old 09-07-2015, 06:19 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
I've owned bikes with 3-speed, 4, 5 and 6 and looked for an extra gear on every one - it's normal and you shouldn't go buying a new trans just because of that! If you buy a 7-speed and still look for another gear what ya goin' to do?!
All our bikes come with tall gearing, even the 5-speeds, so give some careful thought to what you would like to achieve. I can see the attraction of a DD6, to give a lower first gear and slightly taller top gear, rather than the Baker approach of simply raising top. A DD7 has me scratching my head!
As for a bigger engine they are readily available in a box, at quite decent prices, it seems extravagant to have one custom built, unless you are after a real performance machine. H-D make two versions of their SE120, JIMS offers a 131", but the S&S 124" would get my money.
Old 09-08-2015, 05:13 PM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
OD6 if you do a lot of highway time other wise a 5 speed. 7 speed is for 07 and later bikes.
Old 09-08-2015, 08:04 PM
Mikeron1's Avatar
Mikeron1
Mikeron1 is offline
Gonna stick with the stock 5 for now . It will be the baker od6 if I do though .. Thanks
bobsemp
Engine Mechanical Topics
12-22-2017 10:32 AM
djl
07-31-2014 07:58 AM
NYdyna
05-02-2012 11:40 AM
lastbike
06-25-2008 06:39 PM
95hd883
05-20-2008 10:03 AM
Quick Reply: 5 gear or dd7
