Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Bike won't upshift
Old 10-20-2015, 02:59 PM
Booey424's Avatar
Booey424
Booey424 is offline
Default Bike won't upshift
2003 883r with a newer SE clutch.
I just changed the trans oil about 100 miles ago. At first when I went into 1st gear, it was fine, then into 2nd was good, 3rd good and so on. It ran fine
Then it would go 1st to 2nd no problem, but then 2nd to 3rd it would go into neutral. I would have to downshift back to 2nd, let the clutch out and then re-shift to third. And it would go through the gears no problem
Now it will not even go from 1st to 2nd. It just hits neutral and that's it. I can downshift back to 1st but that's it.
I checked the fluid level and it is right on the line. I used the SE SYN3 fluid.
Old 10-20-2015, 03:35 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,925 Likes on 3,023 Posts
It's either the clutch basket adjustment or the gears are palled.
I use Redline in the Tranny and HD primary fluid in the primary.
Old 10-21-2015, 08:34 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
Make sure your shift linkage is not binding somewhere.
CVO SG
Milwaukee Eight (M8)
18
06-06-2017 01:47 AM
Jim Achey
06-25-2015 03:23 AM
Lawdawg
09-20-2010 11:11 AM
flstfjeff
03-24-2008 09:14 AM
stubby
10-17-2006 12:08 PM
Quick Reply: Bike won't upshift
