leak on left side engine shaft
that guy would be a legend in his own mind
ultima has a shovel case its fine it works as well as the OEM one would[/QUOTE]
Well, I guess bang for the buck would be the Ultima.I was planning to have my crank balanced and welded no matter what case I use. No monster. Everything now is stock besides the carb and the cam. All she's for is putting around town.
Does this plan sound Sufficient ?
That welding bit is only for twinkies, shovels don't need it as the cranks are rebuildable not disposable. They will balance out fine and pull 6500+ plus RPM just as they are.
Down side to going new cases is gonna be re-regersiting with the DMV , getting a special construction title issued and having those ugly *** tags glued on.
I'd go on the hunt for an OEM left hand case and have yours match machined and lapped in , they are out there.
I'd go on the hunt for an OEM left hand case and have yours match machined and lapped in , they are out there.[/QUOTE]
Ok, I actually know someone with a left side. I just don't feel like having this happen agian...
Good point, I can keep my engine number.
Thanks man, thats what I'll do.
Know of any quality shops? I done stuff with revaluation performance in Wisconsin.
