Best Cruising Speed
RE: Best Cruising Speed
On my RK with a 88cu and 5 speed, I keep very accurate mileage. Iget 45-47 runnin 70, 48-50 if I stay under 60.My 80cu shovel and 4 spped, like Silvergoldsmith said, get even better milage.
My shovel does have a 22 front and 48 rear sproket, so it runs higher than stock gears, but is very happy at 60-65 and gets 51mpg. I use more for in town, short road runs.
Bottomline, IMO feel your bike...where the harmonics (vibration) is the least. Even if the mileage is not as good, your motor will be much happier and be kinder to you if you run it where it like to be....IMO each motor may vary, but look in your mirrors, etc, Mysporty, also bolted to the frame like the shovel, did not seem to be happy at any rpm, where both my 86 FLHTC and this shovel have a happy rpm...
Good Luck
Hogback
Good Luck
Hogback
ORIGINAL: HogBack
Bottom line, IMO feel your bike...where the harmonics (vibration) is the least. Even if the mileage is not as good, your motor will be much happier and be kinder to you if you run it where it like to be....IMO each motor may vary, but look in your mirrors, etc, Mysporty, also bolted to the frame like the shovel, did not seem to be happy at any rpm, where both my 86 FLHTC and this shovel have a happy rpm...
Good Luck
Hogback
Good Luck
Hogback
The conditions while riding will also be a factor, wind, temperature, how heavily your packed down, quality of fuel and elevation.
my shovel would run all day long on the flats @ 65 to 70, this was the sweet spot if everything else was optimum conditions.
The little I've ran my stroked shovel I can tell its going to want to run 70, this is when it smooths out. Wish the roads around here were better. [:@]
1983, cruising, crusing, davidson, flhs, good, harley, long, motorcycle, motorcycles, rpm, shovelhead, speed, speedharley, trip5, whats
