voes
I found the VOES to be very useful on my 1980 FX. I installed a Dyna 2000 ignition and the instructions mentioned the VOES, but I had no idea what it was. Looked into it, but couldn't use it.....no vacuum ports. However, I did install a micro switch to activate full timing advance of the Dyna 2000. This was useful for checking timing at idle and for fuel economy. Later I installed a Thunderheader exhaust. But in order to get the motor to run right, I needed to install a CV carb. Once the jetting was set correctly, I decided to install a VOES using the vacuum port on the carb. This allowed me to run in the "economy mode" (full advance) when I wanted, but, when I twisted the throttle hard, the VOES dropped the full advance timing out, and reverted the Dyna 2000 back to the preset timing curve I initially set up. The advantage to all of this is, no more pinging, the timing advance dropped back to a less aggressive ramp up which resulted in a lot more low end torque.
When running a HI-4, There is a dip switch for OEM ignition advance curve and Race curve. On race curve, the ignition jumps to full advance off of idle. Using the proper fuel (93 octane), at full advance, and the motor properly timed, there should not be any "pinging" on a street motor with comp ratio's up to 10:1, no matter the size, up to 100".
"Properly timed" is a key issue. Many people center slot the backplate and call it good. Doing this will cause the ignition to be up to 10 degrees off, one way or the other.
On the HI-4, the instructions say to bring the front cylinder up to TDC and adjust the backplate till the red light comes on. This is a static time, and still could be 5 degrees off. This proceedure is just to get the bike started so you can fine tune it. No matter what ignition you run, they have to be fine tuned, with or without VOES, though OEM points are a lot more forgiving.
I've attached a picture of my drag strip queen with a HI-4. 80 cid, 9.75:1 ratio. I know the brake pedal is in the way a little, but you can see the HI-4 is nowhere near center-slot.
I agree, I installed a VOES on my '82 with the HI-4 and it was more of a pain in the *** than it was worth, it's in the bottom of my tool box now.
Good luck with your decision.
