Need help, primary allllmost off
Still working on getting the primary off this shovelhead. I have all the bolts out, starter out, solenoid out but the case is getting caught up on a little piece of metal on the shaft that holds the clutch. I dont know what its called but Im gonna post pics. The close up shows the little raised metal piece keeping the case from coming off. Not sure how to get around it.
Just mess with it a little bit...I've seen them be pretty tight and I've seen them just about fall out.
The keyway is ramped at the tranny end so when you tap it, it won't go anywhere that you don't want it to.
Don't beat the **** out of it...Just kind'a tap it.
