4 piston rear caliper from Performance Machine.
Anyone here running a rear Performance Machine 4 piston caliper? I'm looking for something that will help pedal effort on the rear of my Wide Glide. While I can get it to lock up, I dam near have to stand on the pedal, and i'm looking for something to reduce the effort. The front works great, but the rear is crappy. Lets here what you have to say.
You need to ensure you have the correct ratio between MC and caliper piston. http://www.vintagebrake.com/mastercylinder.htm
Ok, let me be perfectly clear. The FRONT brakes are GREAT with NO PROBLEM what so ever. The rear brakes suck *****! The pedal is firm and feels great, it just doesn't stop worth a crap, and the only way you will get it to lock is if you stand on the pedal! Pedal is stiff and feels great, it just doesn't stop worth a ****. 800 miles on this bike since I rode it off the dealers lot brand new and it's been this way the entire time. With that said one of the guys I work with rode his '07 Dyna today and I was talking to him about it. He said his was at the other end of the spectrum, and he could lock his up very easily. I then looked at his rear caliper and it was a factory 4 piston instead of the 2 piston like my '16 has. I should note mine has factory ABS. I also talked to Rick at Performance Machine this afternoon and he told me that Harley in the last few years was bad about putting a master cyl. on with a bigger bore than what was needed so it would kill the "touchiness" of the rear brakes. Being a mechanic for 40 years I don't think a brake pad upgrade along with braided lines would get me close to where I want to be on this or i'd order them in a second.
As far as seeking technical advice, I'd call Wilwood, Brembo, Tokiko, etc. before I would PM. PM makes pretty parts, for sure, but their business isn't actually performance brakes. I'd bet Hward Messner at Motorcycle Metal knows a thing or two about stopping a Harley, too.
The following 2 users liked this post by cggorman:
relykz (03-24-2017),
TwiZted Biker (03-25-2017)
Good pads can't hurt, might help a LOT, and cost a small fraction of a PM caliper. What's the down side?
Well Chris I went ahead and ordered a set of the best Lyndall pads and will give them a shot. Worst case is i'm out $70 on pads, but if they perform like there website says they will it should get my rear brakes a lot closer to where I want them.
I'm an EBC guy, but Lyndall is good too. Friction material choice can vary based on your preference. Many high performance pad materials can have a lower initial bite but come on strong as the rotors and pads heat up. Many street materials are the opposite. They have very high initial bite and fall on their face when hot. And, of course, you can find compounds in between. I like the feel of a more performance oriented compound, but we're all different.
Remember to bed in the pads per the mfg. recommendation before making a determination on how you like them or trusting them in critical use.
Like you said, worst case you're out $70. It can take several different tries before you find your perfect compound.
