Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
You can use a little blue Loctite, but don't use red. Personally I just use a little engine assembly lube so I can torque the base nuts to spec. Ditto with head bolts.
Where are you putting the loctite ? One experience I had was with the previous bike. Heading to Hot Springs, AR. Following a couple of guys in the twisties, went to downshift and got nothing.. looked down and the shift peg was gone ! Managed to pull over and get the lever in N. Walked back a block or two and the peg and bolt are sitting in the middle of the road ! Put loctite on and away we went. I never leave home without it.. And I put it (blue) on most all screws.
The Loctite guide specifies anti-seize for the head bolts.
I've heard, when in doubt, use blue. I was going to go that route on the base nuts if I didn't get a more experienced opinion.
