Use Loctite or not
Old Mar 22, 2009 | 04:05 PM
forever young's Avatar
forever young
Default Use Loctite or not
I sure hope I'm not the only one who's had this happen. Every now and then the bolts that secure the dog bone mount to the forward cylinder of my XL1200R would come loose. No big deal, just annoying. So, I went and bought new bolts, new lock washers, some blue Loctite and a service manual. After I put a drop of Loctite on each bolt I torqued them to spec., which is pretty damn tight at 55 to 65 Ft. Lbs. Anyway, after a nice long cruise I realized the Loctite tube says it has a temperature range of -65 to +300 degrees fahrenheit (probably should have read the directions first, duh!) Seems to me the head will get hotter than this. Anyone know if I did a stupid thing and should remove the bolts and clean off the Loctite, or should I just say the hell with it and see what happens?
Old Mar 22, 2009 | 04:43 PM
phatman's Avatar
phatman
you should be fine.
Old Mar 22, 2009 | 04:46 PM
gunner11's Avatar
gunner11
No problem.
Old Mar 22, 2009 | 05:40 PM
forever young
Default Answered my own question
After the bike cooled down I rechecked the torque. I was able to loosen the bolts with a short 5/8 wrench with light effort. Apparently the Loctite boils off at high temperatures and can cause loosening. I cleaned the bolt threads and bores with compressed air, put a tiny pinch of anti-seize on the first thread of the bolts, then ran the bolts in and out a few times to make sure I had cleaned out all of the Loctite. The bolts would bind in their threads till I did this. Then I installed and torqued the bolts. All seems good. Next time I'll read the instructions first!
THanks for all your help guys!
Old Mar 22, 2009 | 05:56 PM
RATROD HOG's Avatar
RATROD HOG
just get some Loctite in a stick,works great
twist it up like a tube chapstick
Old Mar 22, 2009 | 05:58 PM
BucksBike's Avatar
BucksBike
Loctite has a high temp version also. Most auto stores carry it
Old Mar 22, 2009 | 07:20 PM
Dango's Avatar
Dango
Yes...what Bucks said. I put it on everything...including my Wheaties. Haven't s#*t in over 2-years.
Old Mar 22, 2009 | 07:26 PM
ko4qc's Avatar
ko4qc
Talking
So..you are ,literally,full of "s#*t" ?...:>)
Sorry,couldnt resist the opportunity...:>)
Old Mar 22, 2009 | 09:03 PM
Dango's Avatar
Dango
Good one! My wife thinks so at times.
Old Mar 22, 2009 | 10:03 PM
gator9999's Avatar
gator9999
after a weekend of drinking, I might consider the loctite to slow things down ;P
gli.der
Aug 18, 2010 04:06 AM
AdrianVall
Mar 19, 2009 07:14 PM
SuperFastGlide
Dec 30, 2008 06:34 AM
anubisss
Oct 7, 2006 02:33 PM
lkbenson
Jun 1, 2006 02:29 AM
