Thread locker...retorqueing.
Old Aug 17, 2010 | 07:04 PM
gli.der's Avatar
gli.der
Default Thread locker...retorqueing.
Whether checking for loose bolts before a ride, or going through the manual and retorquing any and everything during scheduled maintenance, is there not an issue with breaking the threadlocker? Seems to me that if the bolts breaks loose and you get an extra inch lb. or 2 that it would need to be removed and threadlocker re-applied. Am I over thinking this, or is it a legitimate concern?
Old Aug 17, 2010 | 07:17 PM
harry.b's Avatar
harry.b
Personally, if the bolt moved when retorquing, I would remove the bolt, clean, and retorque. Most of the bolts that are 18 ft/lbs or more don't require loctite. The only ones that have run into are the shock to swingarm bolts. They require three drops of 243 loctite. Some of the critical fasteners are the motormount and stabilizer bolts. These bolts do not require loctite as per the manual. Look at the manual and if it mentions loctite on assembly and they move when retorqued, remove and clean. The craftsman 40 piece thread chaser set is all you need.
Old Aug 17, 2010 | 07:23 PM
Dionicio's Avatar
Dionicio
Just set Your torque wrench just below the specified torque. If the fastner moves, take it out ,apply threaderlocker and retorque. If it does'nt move, Your good to go.
Old Aug 17, 2010 | 07:50 PM
gli.der's Avatar
gli.der
Good advice...thx guys.
Old Aug 17, 2010 | 08:44 PM
lh4x4's Avatar
lh4x4
When I check the torque and the moves at or before the click, I remove it and reapply the thread locker. Most times the bolt does not move so it does not take very much time.
Old Aug 18, 2010 | 04:06 AM
Meathook's Avatar
Meathook
I'm glad it isn't just me who rechecks bolt tightness at service intervals. My dealer thinks I'm crazy to go over the bike every 2500 miles and checking them because of the lock tight.
+1 on the comments.
cc75
Dec 31, 2014 10:29 AM
forever young
Mar 22, 2009 10:03 PM
SuperFastGlide
Dec 30, 2008 06:34 AM
anubisss
Aug 26, 2007 01:40 PM
beemer737
Jul 11, 2007 09:03 PM
