Red security light comes on
Old 10-14-2015, 04:06 PM
not-so-fatboy's Avatar
not-so-fatboy
not-so-fatboy is offline
Default Red security light comes on
Hi, I am having a random problem with my 2011 Fatboy lo with 5,000 miles. When I'm driving sometimes the red security light will illuminate and stay that way until bike has been shut down for awhile. The odd thing is that I noticed that when the red light is on I have no brake light! The running light is illuminated but no brake light. When the red light is off I have brake lights!
Any help would be greatly appreciated!
Thanks in advance
Old 10-14-2015, 05:52 PM
Misbehaven's Avatar
Misbehaven
Misbehaven is offline
Could be a bad BCM. Some of the 2011's were recalled and the BCM's changed.
Old 10-14-2015, 06:48 PM
ChickinOnaChain's Avatar
ChickinOnaChain
ChickinOnaChain is offline
Big Kahuna HDF Member
Received 3,070 Likes on 2,554 Posts
Take it to a dealership or indie shop.
Old 10-14-2015, 07:56 PM
uklauren's Avatar
uklauren
uklauren is offline
Florida Crew Moderator
Received 3,389 Likes on 1,560 Posts
Sounds like my 12 Heritage that had electric gremlins. Voltage regulator?
Old 10-15-2015, 09:41 AM
DynaJ's Avatar
DynaJ
DynaJ is offline
my 05 fatboy does this some times. Crazy thing is if I hit the clutch side handgrip it shuts off...You might have a wire pinched in your hand controls. Also check your battery I have seen the light come on when someone needs a battery.
Old 10-15-2015, 10:22 AM
1004ron's Avatar
1004ron
1004ron is offline
Is that a FOB battery you're referring to?
Old 10-15-2015, 11:52 AM
DynaJ's Avatar
DynaJ
DynaJ is offline
Bike battery. I have had a bikes with no security system throw a red light because of the bike battery.
Old 10-16-2015, 09:38 AM
Philphine's Avatar
Philphine
Philphine is offline
that happened to me when i pinched one of my turn signal wires in a wire clamp. the red light would come on and my right turn signal wasn't working. stopped as soon as i unclamped the wire (haven't even been in the wire insulation to see if it broke/frayed. that part is a little strange to me). maybe check for good continuity on the brake light wire. try to move it around while you have a meter or test light on it to see if you get any change/fluctuation in the reading.
wc00000001
05-27-2018 09:54 AM
Jeff42899
Electrical/Lighting/Alarm
06-07-2016 07:48 PM
SHADEY
02-26-2016 02:05 AM
Stroked sportster
09-01-2012 07:33 PM
Cep10SG
12-12-2011 01:45 AM
Quick Reply: Red security light comes on
