87 sportster tail light problem
Old Sep 1, 2012 | 07:33 PM
Stroked sportster's Avatar
Stroked sportster
6th Gear
Exclamation 87 sportster tail light problem
I have an 87 sportster 883 hugger, I recently just bought a doss tombstone tail light from J&P cycles (part number-3400520). Upon installing it the brake light would not work correcting, the brake light will work with no running light, but when i have the running light on the brake light does not engage when pressed down. I used a test light to figure out which wire controlled the running light and brake light. The running light is green off the bike and the brakelight is red off the bike. the tail light has 3 wires comming out of it black, blue, red. black is ground, blue is running and red is stop we assumed. like i said the brake light works when the key is in the on position, but does not engage in the running light position the light just stays bright and solid as if the brake light is always on. any help on this problem would be very helpful, thank you!!
bikefxds
May 30, 2014 09:10 PM
Swigs03
Jan 29, 2013 07:18 AM
adamsrotors
Jul 16, 2012 03:24 PM
Cep10SG
Electrical/Lighting/Alarm
Dec 12, 2011 01:45 AM
moondog99
Aug 12, 2010 08:06 PM
