starting amperage on Night Train?
Old 11-01-2016, 09:29 PM
rquest's Avatar
rquest
rquest is offline
Default starting amperage on Night Train?
I just bought my new to me '07 Nght train, it only has 11k miles and has a new-ish after market battery. It seems like it has a good charge but will not start the bike after sitting in a comfortable garage in LA for a couple of nights. Changed the plugs, checked for spark, got a new fob battery, etc. Will start with a jumper so I'm thinking it's just not getting enough amperage. Does anyone have advice (possibly on the best battery) or know what the starting amperage should be on this bike?
Old 11-02-2016, 12:19 AM
Next In Line's Avatar
Next In Line
Next In Line is offline
Have the battery load tested to see if it good or not.
Old 11-02-2016, 12:31 AM
JesseDyna's Avatar
JesseDyna
JesseDyna is offline
Other than battery load capacity, it can possibly be a few things:
- Battery needs to be revitalized if it was sitting. A few days on a trickle charger or especially a smart charger could bring it back.
- Parasitic loss - something on the bike is causing battery to drain. Would require an ammeter to test. Can also connect a 1 ohm resistor in series with the battery cable to the battery and measure any voltage. Ohm's Law at your service. Not for everyone.
- Loose battery connections - this is possibly the most likely even if odds are still low. Been bit by this a couple times. Start with the simplest things first.
I would also check the voltage of the batt before and after operating. It should be higher after operating than lower. Bad charging system could be a culprit.
Your manual should say the ratings for the battery cold cranking amps. If you don't have one I think Harley will provide one to you online for that year if you sign your life away to sign up for their web site.
rquest (11-03-2016)
Old 11-02-2016, 10:05 AM
dfwhockey17's Avatar
dfwhockey17
dfwhockey17 is offline
Old 11-03-2016, 01:05 AM
rquest's Avatar
rquest
rquest is offline
Thanks for the advice guys. But I think the load test is a little different than reading the starting amperage, would anyone know what that is supposed to be? And is there anything like the "best" battery for a Night Train?
Old 11-03-2016, 10:06 AM
dfwhockey17
Don't buy Chinese. Yuasa or Deka (or any of the private label Dekas) are the best batteries IMO. They are both made in the USA and Deka is the OE battery for your bike. Both of these batteries will be over 300CCA.
Once again, having your battery load tested will let you know if it is good or not. What brand is your new-ish aftermarket battery?
Old 11-03-2016, 10:41 AM
1004ron's Avatar
1004ron
1004ron is offline
Most don't measure the cranking amps, and I doubt that you have an instrument to do that, but its not really important if the jump starts it, as that is a clear indication that the battery is failing.
It might achieve full charge voltage, but if it sulphated it will not be able to deliver the amperage, hence the need for a free load test at AutoZone.
www.batterymart.com has the Big Crank for about $100 delivered.
http://www.batterymart.com/p-Big-Crank-ETX20L-Battery
http://www.batterymart.com/SEARCH.html?q=65989-97C
rquest (11-04-2016)
Old 11-04-2016, 01:29 AM
rquest's Avatar
rquest
rquest is offline
I think this pretty much sums it up... (as others have mentioned also) I'll take it to AZone to test and then try to get through the rest of this year without buying a new one until spring.
Old 11-04-2016, 04:07 PM
1004ron's Avatar
1004ron
1004ron is offline
When my old battery got to that point I also tried to nurse it for a few months, keeping it on the tender everyday, but it didn't get me to the end of the season.
Old 11-05-2016, 11:23 AM
rquest's Avatar
rquest
rquest is offline
Haha, isn't that the way it goes?
rquest
03-05-2017 06:26 AM
soldier of fortune
Electrical/Lighting/Alarm
05-18-2012 06:51 AM
soldier of fortune
EVO
05-15-2012 03:30 PM
soldier of fortune
05-15-2012 09:32 AM
rob90670
VRSC Models
15
09-29-2010 01:52 PM
Quick Reply: starting amperage on Night Train?
