A Night Rod Sleeping Through the Day....
Needless to say, it wouldn't start up. I tried recharging the battery myself by plugging it in via an aftermarket battery lead with a pignose. While it did get my headlight to brighten up, my ignition was super weak.
So, i DROVE (in my dirty celica) down to autozone to get a new battery. they instead took my harley battery and recharged it for me. they called me up and told me that the battery took the charge. then i took it home, threw it back in and ...
NOTHING!! I'm pissed at this point. I mean, you guys know how much crap you have to dredge though just to get the battery out of it's slot.
Presently, it's in my parents garage just sitting there. Now is it time to throw in the towel and pay someone to come out and hook this thing up?
Also, i've noticed that the keyless ignition isn't recognized at all in the start-up process of the bike. As in, when you start the bike up by turning the ignition switch, the bike would usually beep. I've realized that 'beep' anin't happening in the startup process anymore.
Ideas anyone?
Rob
Don't worry, a couple of times of digging around under the airbox and you get fast at it. I do loosen the three bolts on the stacks and drop big fat rubber bands on them before I lift out the stacks. Being a former Cobra helicopter mech, I have a serious aversion to dropping things "inside". On a Snake it could take a couple of days to recover a tiny bolt.
Did I just "press the reset button on my problem" by letting it sit for the 2 weeks? will a push start get it rolling?...ok back to the problem.
My bike will not recognize my keyless ignition, so everytime i move the bike now, the alarm will sound and won't quit till it times out. so not only will it not start, when i move it i'll set off the alarm , making a racket. so now i have the alarm unplugged while it sits. now, instead of making a bunch of noise, my speedo panel goes nuts. Turning the ignition switch the the IGN position and hitting my handle's ignition button gives no results, just sits.
Come on, help me and finally give me a reason to buy california mc insurance.
The Facts:
-Bike won't recognize my keyless ignition, forcing my alarm to sound when moved.
-Bike has a new Battery
-Did start up two weeks ago
-It's been hooked up to a tender (a good one, i made sure at the HD shop)
Someone suggested you put a new battery in it... have you done that? We're talking a couple $$$s... that sounds like your problem.
I had no idea that thing has a battery.... to be honest, i've never noticed a screw (where you can open the unit) on it . Will check tonight on it. anyone have a part number on that battery?
DesertSpeed mentioned an AGM battery....is this the same thing guys?
Also i have come across another thread on this somewhere in hdforums.com, had some really good advice in it about this very topic and by one particular user. will try to provide a link...
Rob
FYI: FOB Replacement - CR2032 (3v Lithium Battery)
AFYI: good thread on this topic - https://www.hdforums.com/forum/vrsc-...-rod-help.html - Main Contributer: RobZuc97
