Can you help me pull a nut???
I'm trying like hell to get the compensating sprocket shaft nut off my 92 FXSTS. I've tried the "wood stopper" method, the "metal stopper" method, and even cut a piece of steel to fit between the gears, but I just can't lock that thing enough to get on it, and even when I get some degree of stoppage and pull out my cheater bar to try and loosen it, I'm convinced I'm going to do damage to the bike.
Short of an impact wrench, does anyone have *any* additional tricks of the trade for removing this nut? The shop manual doesn't even have a tool listed to assist with this...
Thanks!
Thanks!
RE: Can you help me pull a nut???
In the case where the comp nut is really tight, an impact is the best method. Locking with wood or metal puts some real stresses on the crank and can in some cases cause the misalignment of the flywheels at the crank pin. I have had to bypass the shutoff on my compressor once or twice to get the pressure up a little to really take off a bad one. I just removed one on my old '72 and found that whoever put it on didn't tighten it at all. I could have backed it off with my fingers. Good luck. Ken
ORIGINAL: shovel52
Shag67
58
09-17-2022 09:12 AM
LQQK_OUT
01-27-2021 12:24 PM
