Few General Softail Questions....
1)I installed fat mini apes on my deluxe and they have provisions for internal wiring, however i chose to not do so, and now i can not get the switch housing/clutch brake housings on the bike without pinching the wires. Has anyone else run into this problem? If so how did you remedy it short of running the wires inside the bars?
2) What size torx bit is used to tighten up the rear floorboards/pegs. The big bit that goes on the frame.
3) i DL'd a tune similar to mine for the PCIII but the pipes are a tad different. I have the crossovers and the tune is for \\; "full exhaust rinehart" will there be any BIG issues?
RE: Few General Softail Questions....
Also, my bike has been running badly, like it has bad gas. It was laid over by my buddy, and i rode it home, no problems other than cosmetic. When i got it back from the painter it was running like its got bad gas in the tank. Starts, idles terrible, then shuts off and white smoke puffs out the intake.
ORIGINAL: AGRV8D
Internal wiring is \\;mandatory when you install APEs...
Sounds like you were in a rush to get the bars on...
I always say.... "You don't have time to do it right the first time but you have time to do it again.."
Take your time with the wiring and splicing. \\; You will be glad you did because it really cleans up the bars.
Mike
NY
Mike
NY
