SLIP ONS
RE: SLIP ONS
You will get all kinds of anwers on this question, first of all personally i would stay away friom the download, if the RUSH are 1.75" baffles and smaller than you could probably get away with out doing the stage 1 &\\; the Fuel management, if you start getting excesive popping on decel than i would do the other two.
RE: SLIP ONS
I agree with Archer1968 - stay away from the download. a power commander isn't but $279 from Fuelmoto, with the correct map already loaded - so, it's a 'plug-in and play' set-up. and with that, you'll need a low restrictive air filter.... my choice is the HD \\;Screaming Eagle.
RE: SLIP ONS
Do you have a high flow air cleaner? If not you'd be ok with a download. It wouldn't be the best solution for lowering engine temps and keeping your engine from running too lean but a download would help. Personally I have a power commander and have been really happy with it. Though my motivation for for buying it was not just because i got new pipes. I wanted more throttle response, a cooler running engine, better fuel/air mix. And the fact that i have a high flow air cleaner really made it necessary to install the p.c.
RE: SLIP ONS
If you have 1.75 Rush pipes or smaller you don't "need" to do anything. \\; I ran them on my Heritage and never had a problem until the packing went bad which I believe made the bike run too lean. \\; Anything larger and they recommend a remap/fuel manager. \\; Some members have reported good results from just adding a product called an XIED for about $100. \\; Plenty of threads already out there on that. \\; You'll find a large thread in the forum tuning section.
