Click, Click, Click When Pushing Start on a 07 Standard
there was a thread that i started in regards to my engine dieing when i have the clutch in:
https://www.hdforums.com/forum/softail-models/250254-engine-dies-when-clutch-is-in.html
my assumptions were possible bad gas which lead me to be wrong. i haven't been able to get it into the HD dealer to see what's wrong with it because i've been traveling a lot with it in EU and so i chose to ignore it. now i'm paying for it.
symptoms:
1. when start button is push in, it clicks
2. battery is fine because light come on and the security alarm is blinking
3. engine doesn't turn over at all any more - just clicks
- last few times it would have a hard time turning over
the bike had the 10K mile check recently by a Spanish HD Service Center and it never ran like it use to. the engine sometimes die when i have the clutch in any gear, and now it doesn't even start.
help...? could this be a spark plug issue?
thanks
stuck in italy
symptoms:
thanks
stuck in italy
Clean the battery terminals, charge the battery or take it in and have it tested an an hd shop to see if it's still good. even if the security and the lights come on there still may not be enough juice to get it started.
sounds like you have dirty terminal connections to me. the might look clean, but you gotta unbolt the battery connections, use sandpaper on the battery and the cables both, then put some dielectric gel on it all and bolt it back together. might not be it, just my .02 but it sure sounds like a dirty connection.
do you live near saltwater?
There is a good chance that during your last service your battery cable was removed and was not tightened properly when reconnected. This would have allowed some corrosion to gradually build up. Disconnect the cables clean the connections and tighten them. Then charge the battery if necessary.
A large percentage of vehicle breakdowns can be directly connected to the last person that worked on them.
Tom
1 Post
Jor3lBR
08-19-2008 10:40 AM
