Drain Plugs on 2007 Heritage
I figure since I have been changing oil on my cars and boat, it's about time to tinker with my Heritage. I have read the manual, and read various threads about fluid changes. In the manual, the engine oil drain plug is a frame connection to the oil tank drain hose...found it. The primary / chaincase plug is in the back bottom corner of the primary...found that too. My question is with the tranny fluid. Manual says the drain plug is under the engine, found it. But various other threads make mention of a tranny drain plug between the shocks..found one there also. Is the plug between the shocks a secondary tranny plug? Is it necessary to pull both when changing the fluid?
If i remember right, the primary plug called for Teflon tape or dope. The trans and oil plugs have an o-ring. The o-ring is a #41 available at Home Depot, Lowes, etc. in the plumbing department. Around a dozen for a buck fifty or so.
somewhere on the web are some really good vids on changing the oils. MY HD hard drive pucked on me couple weeks ago and all saved sites have been lost.. I'll try to find them and post back..
Your investment in a HD shop manual for your bike would be a wise choice. It gives you all of the info you have requested along with the proiper torque specs for ALL of the fasteners on the bike. Personally, I wouldn't turn a wrench without a manual. You can get them from the Dealer for $40-$60.
I use a little dab of the locktite teflon paste (white) on all of my drain plugs , regardless if they have an o ring or not, also always change the o ring with every oil change.
http://www.dudeworld.com.au/HOWTO.PRIMARY.HTML
http://www.dudeworld.com.au/HOWTO.ENGINE.HTML
http://www.dudeworld.com.au/HOWTO.GEARBOX.HTML
these are pretty good tutorials, all bikes similiar.
Thanks
