Backrest installed using Red loctite
Old 01-14-2011, 11:35 AM
colonelangus1's Avatar
colonelangus1
colonelangus1 is offline
use blue or meduim red is NOT required
Old 01-14-2011, 11:37 AM
du510's Avatar
du510
du510 is offline
As Doc VTwin said, I wouldn't sweat it. If you ever need to get it off, heat is all you'll need. I've had to heat up more Jeep & truck parts than I'd care to admit, for the same reason.
Old 01-14-2011, 11:44 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,543 Likes on 3,794 Posts
Good luck, and you will need some heat. I have the original duece sissy pad hanging on my garge wall and the little nut that was crimped to the plastic spins in the pad. The original owner had used blue on everthing. I ended up drilling the button head off. I do not use loctite for this or the seat bolt.
Old 01-14-2011, 11:48 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
Rule of thumb w/LockTite:
-- Red = permanent (secure/items you won't be removing)
-- Blue = secure (items you may want to remove someday)
-- Anti-Sieze = protection (bolts you want to prevent from locking/rusting)
Old 01-14-2011, 03:59 PM
Joe What's Avatar
Joe What
Joe What is offline
How bout green loctite muhahaha try some of that. Just kidding don't try it
Old 01-14-2011, 08:14 PM
musicnbikes's Avatar
musicnbikes
musicnbikes is offline
Yes, stay away from the green loctite!!!
Old 01-14-2011, 09:33 PM
wlbowers's Avatar
wlbowers
wlbowers is offline
Green used to be "wicking" you could actually put it on and it would wick into the threads.
Now you have to be real careful. Colors don't mean diddly anymore.
And this list is a couple of years old.
Loctite
Old 01-14-2011, 10:27 PM
Mr. Lucky's Avatar
Mr. Lucky
Mr. Lucky is offline
Originally Posted by Brad11
I learned about Red loctite after I installed the backrest and it sounds like this stuff is really permanent.
It's not superglue, it'll still come off with application of some heat. If you ever have to remove them, I suggest poking the tip of the biggest soldering iron you can find into the center of each torx, and then crank them off one by one. It should be easy.
Originally Posted by DR. V-TWIN
You can always heat the bolts with a heat gun or hair dryer to break the red loose, but blue for anything that may ever need to come off is s much better idea.
Ordinarily, that would be the way to go. But the OP has a Night Train, which has the black wrinkle strut covers. The hot air blast will level the wrinkle surface surrounding the bolt head.
Old 01-17-2011, 09:41 AM
lazyboy09's Avatar
lazyboy09
lazyboy09 is offline
And the loctite debate continues................................LOL. It's true the color doesn't necessarily mean anything, the only reason they are colored differently is because there are so many types (many more than the typical red & blue ) that it makes it easier for the consumer to tell which one is what they want. There are several different blues and reds also. The typical auto parts store red isn't going to give too many fits coming off, but it's still better to stick with blue in most cases. The stuff is just a plastic that hardens when exposed to metal. I've read posts that suggest you need it to maintain torque not to resist vibration, But it's not a weld so I don't see how it could work that way. We ride Harleys, not watches, Harleys vibrate!
Old 01-17-2011, 10:03 AM
Jackie Paper
It actual hardens from the absents of air. Hence a grade for a loose fitting sleeves or fine and coarse threads with the same call out for retention and the fact that the bottles are only 1/3 full. These grades are not at your average auto parts stores.
goldie
04-28-2018 07:39 AM
Retrax
General Topics/Tech Tips
01-27-2010 09:01 AM
danl
11-16-2009 03:51 PM
MotoPsycho
04-04-2008 10:58 AM
keystonecop620
12-30-2007 04:14 PM
Quick Reply: Backrest installed using Red loctite
