PC Dyno Tune worth it?
Wondering if any one running a PC3 or PCV got it Dyno tuned? Was it worth it?What were the benefits of it? I have a PCV from Fuel Moto with a canned map.The bike runs great no decel pop nothing.I was just wondering if a custom Dyno tune is worth it?The only authorized Dyno Jet facility by me wants 300.00 is that the going rate?
if you spend $2.5K in parts for a motor upgrade or $4.5K-5K if you don't do the work yourself; what's $300 bucks to ensure you are getting your money and peformance out of the build. A base map will probably run OK but a good tuner will make it run great. If you just do pipes, tuner and stage 1, i'd save the $300 and run a base map off the website.
+1 on the advice. Fuel Moto MAPS are pretty close accross the board. If you only have a Stage 1 its not worth it to Dyno if the MAP jamie sent you is running well (no popping, smoth power from idle to WOT) If you do build your engine their will be fine tuning that you will benefit from and its worth the $ to dyno.
+1 MLWILSON
If you haven't done the upgrades then wait until you at least do your cams (if you do them). If your curious as to how the Fuel Moto is treating your motor, most dyno techs will do a test run to show you if your running at the right AFR % for free (or at least my local shop would). Thats when I became a believer that the FP really does suck and does nothing for the AFR (especially engine mods). Good luck.
ryan9977
04-18-2015 11:55 AM
bobby5
Fuel Moto / Jackpot Mufflers
06-03-2010 08:00 PM
