Gas leak
Old 05-15-2012, 09:23 AM
Curdog's Avatar
Curdog
Curdog is offline
Default Gas leak
Every time I fill up with gas I have a gas leak from around my gas cap while I'm going down the road. Gas leaks out all over my tank and blows on me and the right side of my bike. The rubber seal looks good and feels pliable. I make sure the cap is on tight and have even sprayed the rubber seal with silicone. I am planning to replace the gas cap but was wondering if this could be a problem with a clogged vent or something as the glass on the front of the speedometer appears to fog up also as if gas fumes are coming up through the tank dash. Anyone ever have this problem? I don't want to buy a new gas cap if that is not the problem.
Old 05-15-2012, 09:37 AM
oct1949's Avatar
oct1949
oct1949 is offline
The moisture in the speedo is not unusual, the gas issue is not normal.
Are U filling the tank all the way to the top,? if so U might try leaving a 1/2" or more below the filler hole to see if that helps.
Also I fill my up on the jiffy stand, then replace cap.
https://www.hdforums.com/forum/softa...r-fill-up.html
might look through some of these also..
https://www.google.com/search?source....0.aRowxoNc4Y4
Old 05-15-2012, 11:08 AM
mike 09's Avatar
mike 09
mike 09 is offline
Try the vent and check your crossover line.
Old 05-15-2012, 11:34 AM
trozenhorse's Avatar
trozenhorse
trozenhorse is offline
when you fill up the bike is on its side, when it is upright it rises, i leave plenty space and reset my odometer
Old 05-15-2012, 11:42 AM
Scaredofrain's Avatar
Scaredofrain
Scaredofrain is offline
Sounds like you might overfill a little?
Old 05-15-2012, 12:20 PM
kipd's Avatar
kipd
kipd is offline
After filling the tank up my rocker would seep a bit of gas out from the cap area. I stopped at a harley shop told them, they handed over a new cap and the problem was solved, never leaked again.
Old 05-15-2012, 02:37 PM
Jesla's Avatar
Jesla
Jesla is offline
Yup, new cap fixed my Sportsters with the same issue.
Old 05-15-2012, 08:37 PM
rabbit one's Avatar
rabbit one
rabbit one is offline
2012 Heritage was leaking under speedometer , Harley replaced the tank paint came off under leather . Great bike .
Old 05-15-2012, 11:29 PM
av8or's Avatar
av8or
av8or is offline
I have to push down on my cap when I tighten it, or it does the same thing.
jones654
05-27-2020 11:40 AM
pccoder
12-24-2011 09:24 PM
Ashlandeagle
07-17-2011 09:15 AM
billybobber
04-19-2011 10:41 PM
Finksies
08-29-2007 08:09 AM
Quick Reply: Gas leak
