Fatboy shorter gear shift lever
Old 06-02-2012, 10:20 AM
Steve Zodiac's Avatar
Steve Zodiac
Steve Zodiac is offline
Default Fatboy shorter gear shift lever
I need to fit a shorter gear shift lever to my 2009 Fatboy to make it more comfortable. It needs to be an inch or two shorter. Does anybody know if a Sportster lever will fit on the spline?
Old 06-04-2012, 07:31 AM
JakesDad1's Avatar
JakesDad1
JakesDad1 is offline
Pics might help. Looks to me that if your linkage is that much shorter, you will have less play in the mechanism. A small foot tap makes a big shift.
This is the shift lever:
I guess you know that the foot shifter is splined and can be adjusted without adjusting the linkage?
Old 06-05-2012, 06:47 AM
Steve Zodiac
Thanks for the reply but it's the lever itself that I need shortening rather than the linkage. I need to move the peg an inch or two further back.
Old 06-05-2012, 11:04 AM
oct1949's Avatar
oct1949
oct1949 is offline
putting a shorter one on will increase the foot pressure required to shift gears...
2'' shorter may mean a 40% increase...
Are Ur legs too short to reach or foot too small to reach the shifter pad.??
do U have the heel shifter on Ur bike.?? then U could use Ur heel to upshift and toes to downshift..!!
Old 05-04-2019, 12:52 PM
Burbur2's Avatar
Burbur2
Burbur2 is offline
I still would like to know if shorter shifter lever is available for softail or maybe one from sportster would fit?
erljam
07-16-2017 01:13 PM
JfrenchFLHX09
10-17-2015 07:59 PM
DaSham58
12-19-2008 01:34 PM
Cue
07-18-2008 11:36 AM
vet767
04-30-2008 02:41 PM
Quick Reply: Fatboy shorter gear shift lever
