HD sissy bar assembly for Breakout
I have all the detachable equipment as well.. including the sundowner pillion.. however the issue for my girlfriend with a big butt.. is there is not enough fore and aft room between me and the sissy bar.. so its a tight fit for both of us.. I may just fabricate a sissy bar that extends more to the rear and matches the same rake as the front forks...
Ginz choppers can make whatever you want. Mine should be here next week.
In my opinion a sissy bar should be taller than it is wide. The short hd one just doesn't look right to me.
For me, "long and low" is the dominant theme on a Breakout, and a high sissy bar just doesn't fit that theme.
Jim G
- The sissy bar
- The side plates
- The mounting hardware kit
I don't have the part numbers in front of me, but just go to the HD website, go to bike parts, use the motorcycle = Breakout filter, and all 3 items will be evident.
You'll have a choice of fixed side plates or adjustable side plates. The adjust able sidplates are much more costly, but allow you to change the angle of the sissybar within a modest range. This is very valuable if you want to use the sissybar to fasten luggage bags onto.
The whole setup is a little expensive in total, but man I have been very pleased with mine, and everyone who's res it thinks it really looks like "it fits".
Jim G
Sissy bar for Breakout. I am ordering part # 52540-09A Low Rd Mini Medallion
You will need The following parts. 52540-09A Low Round Mini Medallion sissy bar, # 52300239 Docking Hardware Kit, # 53810-00B Detachable sideplate and then you can choose a back pad. I chose # 52300336.
If you mean the HD sissybar, you need to buy 3 items total:
- The sissy bar
- The side plates
Jim G
- The sissy bar
- The side plates
Jim G
I'm almost done with my custom sissy bar project, should have some pics up next week- I got 'pre empted' by the fork springs, damper and tires upgrade (which is just a-w-e-s-o-m-e btw!)
I wish someone made a "wide" version of the Wide Glide sissy bar, that to me would be perfect since it slips nice and clean between the rails and fender. Not quick detach of course, but the low look of it would be ok to leave it on. I agree the stock HD setup bar and pad pushes the passenger too far forward.
The "stretched" Fatboy mod posted above is a nice alternative- I hope the OP can submit some DIY info for others.
