New clutch question...
I upgraded to this Barnett Spring Clutch conversion. Much more positive clutch. More expensive than the Harley diaphragm spring, though. Comes with 12 springs, 6 light, 6 Heavy or you can combo the 2 to make medium. All 3 tensions are heavier than stock.
http://www.barnettclutches.com/coil-...big-twins.html
Very well worth the price and even so if you do the work yourself like I did. Did the S&S upgrade kit with all the goodies. New cam plate with hydraulic tensioners and oil pump. It is a kit from H.D. The cams I chose were T-Man 600. Unbelievable power from the bottom end. Hope this helps. Contact me anytime for any help...
Clutching
Clutch is first weak link in the system for sure. I did a 124" upgrade on my 11 Fatboy Lo and went with the SE six spring with pressure plate upgrade using stock discs. Reasonable cost at 250$ and no slippage thus far through 10k miles and two dyno sessions showing 132torque and 129 HP.
What I was thinking is maybe the plates just need to be replaced.How many miles are on them? The stock clutch is actually pretty tough.
If I may ask, what power are you running, what springs/combo did you use, and how much did it affect the clutch lever pull?
Thanks..
hullhorr
10-27-2013 09:19 AM
