New clutch?
Old Dec 4, 2017 | 02:41 PM
Jay Guild's Avatar
Jay Guild
Default New clutch?
So I did cams, intake, exhaust, big bore with higher compression pistons and am expecting somewhere between 95 and 100 HP. Do I need to replace the clutch plates and put in a stiffer clutch spring? It does feel a bit like it is slipping when I accelerate hard in 3rd gear.
Old Dec 4, 2017 | 02:44 PM
Jay Guild's Avatar
Jay Guild
Also, if you think I should replace, what should I replace with?
Old Dec 4, 2017 | 03:26 PM
Ghost_13's Avatar
Ghost_13
Yes
The scorpion - you'll love it
Ghost
http://www.barnettclutches.com/1840/...998-%2706.html
Old Dec 4, 2017 | 05:15 PM
cvaria's Avatar
cvaria
AIM VPC VP95TL -
https://aim-tamachi.com/collections/...roducts/vp95iv
more
https://aim-tamachi.com/collections/vp-clutch
Old Dec 4, 2017 | 08:01 PM
leafman60's Avatar
leafman60
I have tried various brands and types of clutches and I have been most satisfied with the Alto Carbonite
I've hopped up my Twin Cam enough to slip the stock clutch. Using the Carbonite allowed me to keep my stock easy-pull clutch spring and still handle the increased power of my modified engine.
You can shop around and find these at some good deals. Just for reference, here is the listing used by J&P:
https://www.jpcycles.com/product/630-728?utm_term=
Old Dec 4, 2017 | 10:25 PM
Dyna100's Avatar
Dyna100
I used the AIM VPC. I have 95HP and the easy pull spring. No slip at all.
Old Dec 4, 2017 | 11:38 PM
Max Headflow's Avatar
Max Headflow
All you need for a 97 ci motor is same plate count Barnett Kevlar and a 380 lb spring.. Everything else is different flavored icing..
Old Dec 5, 2017 | 08:31 AM
Jay Guild's Avatar
Jay Guild
What about the 340 lb spring with the extra plate kit? I do a decent amount of in town riding and I've heard that 380 lb spring can be rough on the hands.
Old Dec 5, 2017 | 09:13 AM
Max Headflow
In your case I'd say it would work.. In fact it would probably work with a stock plate count clutch. I ran a stock plate count kevlar with the older 330 lb spring in a my 103 EGC (cr 10 to 1, various cams, ported heads, big throttle body, various exhaust systems) for about 60,000 miles. It starting to get a little slippy at the end. FWIW I went 107 (upped cr to 10.5), bead blasted the steels, added the 380 and it's holding fine.
Some of it depends on what you want to do with the bike, If you want to wheelie, power shift, or burn rubber, you'll need the heavy spring. There is probably some time limit before it need rebuild.
Old Dec 5, 2017 | 09:41 AM
cvaria's Avatar
cvaria
Heavy spring is a PIA in traffic. I went with the se heavy spring over my barnett kevlar extra plate kit.
i have to really man up when in town. The vpc make it easier to live with at speed
