Shut down won't start help
So while leaving the house today my bike shut off while I was moving right in front of the leasing office. I pulled over and it wouldn't start all lights on pushed the start button and nothing happens. It's got power it's not cranking like a dead battery. Also the fuel pump will start to prime then stop then start again or just won't prime at all. She's got power so I know it's not the stayter or voltage regulator. If it was the starter or ignition it would still do something. Also when she dyed while I was still rolling at like 15 mph the gauged went to zero like the gauge died. I'm thinking its a wiring issue maybe a ground or a computer issue. After I pushed it almost all the way home on the way it would ether do nothing when I pushed the start button or it would try and crank fail and then go back to doing nothing. It finally actually started when I was like ten feet from the house. Thoughts on the matter?
If you are saying its not the starter, voltage regulator, or the ignition.....did you check if the battery if it is still good and/or connections. Did you check your plugs? Were you starting the bike in gear or in neutral. Also it would help if we knew how old the bike is or if you had mods done to it.
Johnny Sotelo
General Topics/Tech Tips
06-26-2014 12:55 PM
