any ideas?????????
Old Jul 31, 2007 | 01:24 PM
rollover's Avatar
rollover
Default any ideas?????????
First off, the bike has been a bit difficult to start lately. Push the starter button and it takes a few seconds for the bike to start. Just seemed to be really dragging to get the pistons up to speed to start the bike. Last night I drive it into work and all seems fine except the slow start before leaving. Get off of work and go to start the bike and the power comes on, but once I hit the starter button, the power cuts out. After a couple seconds, power comes back on but when I push the starter button, I get a clicking sound. Try this a couple more times and the bike switches from the clicking sound to the total loss of power. Eventually, I lost power completely and the bike was dead. Buddy at work gives me a jump and the bike fires up immediately. Not even a hestitation. Fires up like it should without the dragging. I ride the bike home the hour it takes and get to the dealer I purchased from and he lets me know it will be about a week before he can even look at it. I tell him I will take the bike home and keep it on the trickle charger and still use it daily until he can get to it. Go outside and the bike is dead. Any ideas? Strator? Voltage regulator? Battery? Just doesn't seem to be charging the battery. Seems like I have been riding on the battery alone without it ever recharging while riding.
Old Jul 31, 2007 | 01:28 PM
Hdbiker1450's Avatar
Hdbiker1450
Default RE: any ideas?????????
There was a thread about a week ago that describes how to tell if it's the battery, etc. You might want to do a search.
Old Jul 31, 2007 | 01:48 PM
mrsr71's Avatar
mrsr71
A suggestion: make sure ALL of your connections are tight [8D]
Old Jul 31, 2007 | 01:52 PM
jrtracker's Avatar
jrtracker
I had a similar problem....... Check to make sure the battery cables are TIGHT....... Mine had come loose and caused the battery to go dead..........
Old Jul 31, 2007 | 02:33 PM
rollover's Avatar
rollover
Some good suggestions guys. The battery connections make sense but would the bike jump start so easily if the connection was bad?
jr, did you have the same symptoms as I was having? Difficult starts where there just didn't seem like enough power to kick the bike over.
Old Jul 31, 2007 | 02:50 PM
TexasRedneck's Avatar
TexasRedneck
Ya've either got loose connections or a battery fixin' ta go on ya.Disconnect the batteryconnections, charge well, test (and note) voltage. Leave disconnected fer 24 hours, retest voltage. If it's more than 0.2 volts lower, replace the battery.
04harleyboy's Avatar
04harleyboy
ORIGINAL: mrsr71
Ditto
Old Jul 31, 2007 | 05:58 PM
rollover's Avatar
rollover
All is well again. The shop actually fixed it this afternoon and the bike is back home. Turns out it was the voltage regulator. Apparently mine was one of the recall units. Looks like it died a slow death and finally kicked today. They replaced it and charged the battery and it starts up immediately now. No more dragging or struggling to start. Props to the Michigan City HD shop as he was swamped when I went in there this afternoon and I was told it would be a week before they even got to look at it.
Old Jul 31, 2007 | 06:18 PM
TexasRedneck
Kewl - thanks fer the update! From the description, it sure sounded lahk the battery - another "helpful info" file saved!
Old Jul 31, 2007 | 07:02 PM
maineultraclassic's Avatar
maineultraclassic
Check to make sure your battery cables are tight, and make sure the ground cable is also tight. Also, make sure there is no rust or corrosion on them too while you are at it.
Samething happened to me, spent 30 minutes checking every fuse and stuff like that. Ended up being the battery connections.
Steve
Coalminerwillis
Jun 13, 2017 10:42 AM
SportyPig
Jun 4, 2010 06:02 PM
alymeg96
Mar 30, 2009 08:45 PM
Night_Train01
13
Aug 27, 2006 10:13 AM
ssgtange
Nov 21, 2004 07:49 PM
