Dyna issues
Old Jun 8, 2017 | 01:32 AM
Coalminerwillis's Avatar
Coalminerwillis
4th Gear
Default Dyna issues
I've had zero issues with my Dyna I rode the other day and the next day i went to hop on the bike and it wouldn't start. The second I hit the start button you hear the relay but the bike loose all power after a minute or longer it's like it resets itself and power comes back, push the start button again just a click and all power is lost. Battery is 100% all terminals are okay and everything on the starter is okay. What else can cause this? It's a 2002 dyna fxd
Old Jun 8, 2017 | 02:16 AM
sparkalot's Avatar
sparkalot
if the battery connections are clean and tight, and the battery voltage is at least 12.6 measured with a volt meter, check for clean and tight wiring connections at the chassis main ground terminal and solenoid terminals.
When you say the bike loses power after a minute, do you mean the engine dies or that battery power dies off? If battery power dies off but comes back again, and the battery is at least 12.6 volts, there is a loose or dirty connection somewhere. A loose/dirty connection point will heat up because of the added resistance, and cause intermittant connectivity
I really hate tracing electrical issues but mostly you need to verify continuity of the circuits involved and verify clean tight connections, not just at the battery but also where starting and charging wiring connects.....a dirty or loose ground connection will cause strange symptoms....good luck
Old Jun 8, 2017 | 03:12 AM
Coalminerwillis
4th Gear
It's the circuit breaker that keeps tripping. I would asumme I have a short somewhere?..
Old Jun 8, 2017 | 04:52 AM
misfitJason's Avatar
misfitJason
Battery, starter relay, system relay. Those are the first things to test/replace.
Old Jun 8, 2017 | 09:12 AM
dyna rider's Avatar
dyna rider
Default Shorts
If the handlebars have been changed, that's where I would start...Or if the switch housings or chrome switch button are installed.
Old Jun 8, 2017 | 10:39 AM
sparkalot's Avatar
sparkalot
Correct. A breaker usually trips because the wire (positive side) that it is protecting is shorting to ground somewhere. If you can find the wiring diagrams for your year and model, you can see where the wires go and where they terminate. I found my Shop Manual on Ebay for about $10 and it was a simple download. It is in PDF format and a lifesaver! Mostly a process of elimination. With battery dis connected, you can test continuity between the circuit breaker 12 volt spade connection and ground. There should be no continuity of course. If you find there is no continuity, however, if you measure resistance in Ohms instead of continuity , you may however find there is a small amount of resistance, meaning there is a stray or "slight" ground....so the answer to that is in the question "What is the acceptable level of resistance, if any at all, in that connection.....there are rectifiers, diodes, and capacitors in many circuits that can show some resistance in a positive 12 volt circuit, even there there is not 100% continuity ......my manual does not give me any "acceptable resistance" on Ohms" , I just mention the Ohm thing because in 12 volt vehicle electronics, it can be a indicator
Bottom line for me personally is there should be ZERO continuity between the circuit breaker 12 volt spade connection and ground Maybe TMI but something to test for
EDIT There is a slim chance that the circuit breaker itself is bad....maybe it is opening pre maturely.....my bike 09 FXDF has relays and fuses but no circuit breaker (as far I can find)
Old Jun 8, 2017 | 11:38 AM
nevil's Avatar
nevil
First thing I would check is the ground connection.
Old Jun 8, 2017 | 07:34 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
You rode the bike and the next start attempt failed? Nothing else done to the bike? How old is the battery? A 2002 possibly with the original rectifier/regulator. Once you get the battery fully charged and tested and the bike started, test for voltage to the battery at idle (13.1 vdc or close) than at 2200 rpms (14.2-14.4 vdc). A good replacement reg. is the Cycle Electric for you Dyna, works a bit differently.
Old Jun 9, 2017 | 09:20 AM
skinman13's Avatar
skinman13
Without knowing what modifications have been done to your bike it is very difficult to pinpoint your problem on a forum discussion, but this sounds like a classic battery failure. If your battery is 3 years old, it is probably time to replace it...
Look at the stickys on this page and run through the tests... https://www.hdforums.com/forum/elect...ting-alarm-43/
Good luck.
Old Jun 9, 2017 | 08:03 PM
seniorsuperglideE8
If you haven't found your circuit breaker yet, pull the the electrical cover off, remove the panel secured by four nuts and the C/B is the item with three wires on it. Remember what wires goes to what post.
