2018+ Softail Models Breakout
Help with Battery issue
Old Jul 3, 2019 | 08:00 AM
king1pin1's Avatar
king1pin1
Default Help with Battery issue
Hello I have a 2001 Harley Fatboy FLSTFI 1450 FUEL INJECTED and have stupidly fitted the battery round the wrong way and messed things up. The result was after switching the ign on and trying to start the bike realised that something was wrong because lights were flashing and then I realised what I had done. I refitted the battery and everything worked Except when i went to press the button to start the bike nothing happened . After a lot of time and a bit of luck I found that the bike would start if I took a live wire direct from the battery to the starter relay so To start bike I do everything up to pressing the button, At that point I have used a door bell button to feed the Starter and the bike starts and runs no problem. I checked all the fuses and all ok so wondered if anyone had any idears. ? thanks a lot for any suggestions .
Old Jul 3, 2019 | 09:03 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Remove the start relay.
Turn ignition switch on, check volatge at the connector you just removed the relay from:
The Black/Red wire should show system voltage only when you press the start button.
The Red/Black wire should show system voltage continuously.
If your voltage readings are as above, throw the start relay into the trash and get a new one.
If your voltage readings are different, let us know.
Old Jul 3, 2019 | 12:53 PM
king1pin1's Avatar
king1pin1
Ok I will have a go at that and let you know , I can say the relay has no power feeding it from the button tho so not relay.
Old Jul 3, 2019 | 03:05 PM
Dan89FLSTC's Avatar
Dan89FLSTC
There is no power on the Black/Red wire when start button pressed?
Old Jul 3, 2019 | 03:11 PM
king1pin1's Avatar
king1pin1
yes thats correct
Old Jul 3, 2019 | 05:09 PM
Dan89FLSTC's Avatar
Dan89FLSTC
I think the next step would be to take a look at the connector for the right hand control switches, make sure no pins are pushed out of the connector.
While you have the connector unplugged you can read out the start switch with your ohmmeter..
Old Jul 3, 2019 | 05:22 PM
king1pin1's Avatar
king1pin1
Thanks I will let you know .
Old Jul 4, 2019 | 04:29 AM
king1pin1's Avatar
king1pin1
Ok so this is what I have found . When you turn on Ignition on power arrives at the relay thro the RED wire with a black stripe then if you press the bikes starter button power arrives at the relay thro the Black wire with red stripe but still no power passes to the starter to engage the starter motor.
Again as i say I have rigged up a live feed thro the green wire into the relay and this starts the bike but not good longterm.
It looks like its the relay but I swapped with the relay next door and it did not work . As we have now worked out ( With help from all off you ) that power is coming down the Black / red stripe when the button is pressed , Could I just bridge behind the connector to the green wire that seems to work ?.
Again thanks for your help with this problem that has caused me sleepless nights.
Old Jul 4, 2019 | 05:02 AM
Jackie Paper's Avatar
Jackie Paper
https://www.hdforums.com/forum/sport...bike-dead.html
Old Jul 4, 2019 | 06:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
With relay re connected, try connecting a temporary wire to the Tan/Green wire, run it to ground.
You can just wrap the strands of the wire around the pin on the relay where the Tan/Green wire goes, then install the connector.
This will give the relay a ground, if this works, the problem may be the TSM or TSSM, whichever type is on your bike.
