Battery Tender Spade Position
The pigtail positive spade. The service manual states that the Maxi-Fuse spade is supposed to mate with the battery terminal. My question is does the pigtail spade take the position mating with the battery terminal or sandwiched between the Maxi-Fuse spade and the battery cable ?
Right. The terminal spades with the hole that mate with the battery. I thought that my wording would be understood. I'll ask again.Is the battery tender pigtail terminal supposed to be the 1st connection flush against the battery or sandwiched between the Harley Maxi-Fuse and the battery cable?
It doesn't matter.... however it fits best.... it's all the same connection point.
FenderGuy53
08-18-2011 10:35 PM
