Can a used smart security system be used again?
Old 03-27-2011, 07:56 AM
lanew's Avatar
lanew
lanew is offline
Stage I
Default Can a used smart security system be used again?
Dear HOGs, I bought a used set of smart security system from eBay for my new Sportster 883R. But the dealer told me that the set was programed and linked to one particular computer and they could not unlock them. So the system can not be reused. And the fob does not have the codes on it so the fob can not be reprogramed as well.
I am a bit skeptical to their allegations. Does it mean that the TSSM can not be used by another bike once programed? And there is no way to reprogram the fob if its codes are lost?
Looking forward to your inputs.
Thanks!
Old 03-27-2011, 08:34 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,923 Likes on 3,022 Posts
Not sure, but I would think that the code is in or on the fob somewhere or a number to cross reference through the manufacturer or stealer with proof of bike ownership. also I would think that the security system is a self contained unit that just plugs or hard wires in to kill the engine and sound horn.
On a lighter note you could rig a relay to some Symtech (C4) but I wouldn't recommend it. just kidding
Old 03-27-2011, 11:26 AM
HarleyScuba's Avatar
HarleyScuba
HarleyScuba is offline
That "married to the bike" issue is true for Screamin Eagle Race/Super Tuners, but I don't think it applies to the alarm systems. Plug it in and see what happens. Here are the install instructions, but they aren't much help:
http://www.harley-davidson.com/en_US...ts/-J04082.pdf
Old 03-27-2011, 02:21 PM
Swanny1172's Avatar
Swanny1172
Swanny1172 is offline
6th Gear
Install it and program it according to these instructions from NRHS.
http://www.nrhsperformance.com/tech_xllearn.shtml
Old 03-27-2011, 07:48 PM
HarleyScuba
He's installing a Smart Security System, not a tuner. I only mentioned the tuners because that's what may be confusing the OP's dealer. I don't think there will be a problem with the alarm. I don't remember hearing about any. Maybe call another dealer. I was a parts monkey at a dealer, but I could be wrong.
Old 03-28-2011, 05:02 AM
Swanny1172's Avatar
Swanny1172
6th Gear
The programming sequence is the same for the ignition module and the security module. I used these exact directions when I installed a security system on my bike and they worked perfectly.
Old 03-28-2011, 06:08 AM
Von_Zipper's Avatar
Von_Zipper
Von_Zipper is offline
It is not married to ECM, I removed factory ECM and replaced it with ThunderMax and security is still working.
I'd contact the seller and ask for fob serial numbers, just in case. I have stickers in my owners manual with serial numbers for both fobs.
Old 03-28-2011, 08:41 AM
HarleyScuba
I learn something every day. Thanks.
Old 03-28-2011, 04:38 PM
hogsport's Avatar
hogsport
hogsport is offline
That si the exct sequence I used to instal the TSSM for my HD security system.
There is another sequence to set YOUR password, and another to mate the key fob to the TSSM.
You will want to have the bike on a tender and a coolser handy. You will be an hour getting everything done if you get it done right the first time.
steelerdude1
2014-2023 Touring Models
14
01-30-2021 08:45 PM
willshort
09-24-2018 02:21 PM
jeremyreed
06-19-2017 08:08 PM
etxabier
05-27-2013 08:42 PM
DensFLH
05-21-2006 09:31 PM
Quick Reply: Can a used smart security system be used again?
