Transport/Travel Mode sequence.
I have a minute:
1. Turn the ignition switch to ignition.
2. Set the engine stop switch to off
3. With FOB within range, turn the ignition from "ignition" to "ACC"
4. Simultaniously press both the left and right turn signal switches. This must be done within 5 seconds if turning the ignition switch to ACC
5. After the turn signals flash once, turn the ignition switch to OFF and the module is armed
6. Confirmation: Turn signal blinks 3x when armed for one ignition cycle
To exit tp mode:
With fob present. turn the ign switch to ignition, set stop switch to run
To exit tp mode:
Jpulver (11-22-2020)
I have a minute:
To exit tp mode:
To exit tp mode:
