Clutch won't disengage
03-13-2012, 10:57 AM
I performed a clutch adjustment and cable adjustment per the service manual and youtube vids. I still find it very hard to "find" neutral and once I do, even with the clutch lever fully pulled in, the clutch doesn't seem to fully disengage. it won;t shift to first easily. It "buzzes" like you are trying to fit two spinning gears into each other. Any advice? Also, when the engine is off and I am in 1st gear, when I pull the clutch lever, the bike will not roll like it does when in neutral.
2003 883C
Steve
03-13-2012, 11:08 AM
Perhaps too much oil in the primary? When did this trouble start?
03-13-2012, 11:22 AM
Have you checked the adjustment of your primary chain?
03-13-2012, 12:47 PM
How many miles on the bike?
Have you ever replaced the clutch Spring Plate?
03-13-2012, 01:10 PM
My oil level in the primary appears fine. I bought the bike with this issue.
No I haven't adjusted the chain. There should how much "play" in the chain. 1 to1. inches right?
58,000. The previous owner did Energy One Peformance Clutch
EZ Clutch kit
03-13-2012, 01:38 PM
cold eng = 3/8 to 1/2 inch
hot eng = 1/4 to 3/8 inch
03-13-2012, 01:58 PM
06-15-2015, 12:42 AM
Whatbwas the isssue and fix? Im having the same issue after rebuilding my motor.
B-Duff
09-14-2011 01:01 PM
jmass
05-12-2010 10:58 AM
Chopperz
10-31-2008 09:37 PM
UglyLou
06-25-2008 03:46 PM
Skivvy9r
03-27-2008 07:06 PM
03 ,
1200 ,
2003 ,
clutch ,
davidson ,
disengage ,
engage ,
find ,
hard ,
harley ,
hd ,
neutral ,
shift ,
sportster ,
statt ,
wont
