Clutch or Primary Or Tranny??? ahhhhhhh
so I went out for a ride the other day... & realized that my clutch was shifting tight, when I engage the clutch to shift it was hard, when I was down shifting it was engaging... but very hard on the clutch pedal.... while stopped I was in first gear & realized that the sportie was slowly inching forward even though I had the clutch lever pulled. now.... heres the kicker... IT POURED that afternoon & I ended up riding through some big puddles... what the hell do I do without going to a dealership, can this be diagnosed on my own.
FYI, Ive put over 4k on the bike this summer
If this thread is confusing.... sorry.. Imagine me trying to explain... Im a chef for gods sake
16k
not sure, bought it used from a dealer, they did a thorough 10K checkup when I bought it
I have tools and am purchasing a manual
Received 3,952 Likes
Sounds like it's time to adjust the clutch and change/check the primary/trans fluid...and lube the clutch cable at the same time.
Kevin
Kevin
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
ya. simple to do really. once i did it i was think'n "wow, that's it?" I just used a piece of wood under the kickstand to prop her up during.
http://www.youtube.com/watch?v=invnrw3nj3U
Inching forward when you have the clutch lever pulled in means either there is too much slack in your clutch cable, or your clutch may need adjustment.
I'd verify the cable is adjusted properly, and if its still exhibiting the problem, then go take a look at the clutch adjustment (with a service manual and tools at the ready).
Ok. Last night I used mr delboys vid! I adjusted the clutch cable, lubed the cable, changed primary fluid, changed the oil & adjusted the clutch... Gonna take it for a ride tonight! it did well when I spun around the NH last night.
TBC
Thanks for the help guys.. as always... Sportie forums save the day
TBC
Velocity1
07-28-2013 08:35 AM
