Dragging clutch
Old Mar 8, 2015 | 03:13 PM
Big Dave's Avatar
Big Dave
Default Dragging clutch
I cant seem to adjust it out , carefully set up as per manual , clunks in to gear , hard to get neutral and can feel it pulling with clutch in ever so slightly but its definitely dragging . new to me 1998 RK 5 speed 40,000 miles
Dave
Old Mar 8, 2015 | 03:30 PM
grbrown's Avatar
grbrown
Dave, my bike is earlier than yours, but the process I use is to adjust at the clutch as per the book, but then take out most of the cable slack, when setting the in-cable adjuster.
One possibility is that your bike has an aftermarket device installed, to lighten the clutch lever action, which are infamous for 'stealing' spare clutch adjustment. A dragging clutch is not unknown in Evos circles, one antidote being to snick into neutral while still rolling. That doesn't solve things in every situation, but is a natural action after 25 years of Evo riding in my case!.
Old Mar 8, 2015 | 05:48 PM
Dr.Hess's Avatar
Dr.Hess
Yeah, make sure you don't have one of those "easy clutch" things. I put one one the sporty and it cost me a clutch. Next, after everything is adjusted per the book including the clutch and the primary chain, change your primary oil to Mobil 1 ATF.
Old Mar 8, 2015 | 06:15 PM
Big Dave's Avatar
Big Dave
further inspection finds an Haydon M6 chain tensioner that seems to be working OK , im leaning toward clutch plates and oil , bike set for 3 years before i got it and ive put about 500 miles on it , PO used 20-50 revtec oil and it was just changed when i picked it up , is ATF thinner ? which is what i want
Thanks
Dave
Old Mar 8, 2015 | 07:57 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Thanks
Dave
Yes ATF is thinner.
Old Mar 8, 2015 | 10:02 PM
Spanners39's Avatar
Spanners39
20-50 will make your clutch drag, you need to use either ATF or a generic Hypoid Gear Oil 75w 90 weight.
Old Mar 8, 2015 | 10:19 PM
SeaZund's Avatar
SeaZund
ATF good for Pans and Shovels as well? (recently had my shovel clutch apart replacing the pushrod and TO bearing)
Old Mar 8, 2015 | 10:24 PM
Big Dave's Avatar
Big Dave
Shovels use a wet primary but only 8-9 oz's and are a dry clutch oil is only for the chain
Dave
Old Mar 8, 2015 | 11:26 PM
Spanners39's Avatar
Spanners39
I don't personally like ATF, it falls out, I use the generic Hypoid gear oil I mentioned.
Old Mar 9, 2015 | 11:55 AM
Big Dave's Avatar
Big Dave
Right or wrong
I put mobile 1 in the tranny and redline MTL in the transmission
Will let ya know tonight
Dave
