Slipstream Heated Grips.
Old 11-17-2014, 11:34 AM
Pappa P's Avatar
Pappa P
Pappa P is offline
Default Slipstream Heated Grips.
I had a set of Slipstream Heated Grips P/N#56100027 installed on my 2015 Ultra Limited. I was not happy with the switch housing on the left grip so I decided to see if I could correct the issue. Long story short, I removed the left grip from the handlebar and disconnected the internal wire from the grip. Everything that I have read has said the end of the wire/connector should extend past the end of the handlebar, it doesn't, it is about 5 inches from the end of the handlebar, I have a mechanical grabber that I am able to grab the end but it does not want to come out. I have removed the front fairing, which is pretty simple to do, but I cannot locate anything that may or may not be the wire that connects the left grip to the right grip. Has anyone had this issue?
Thanks!
Old 11-17-2014, 12:48 PM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
I thought those wouldn't be wired internally....
And what were you "not happy with"?
Old 11-17-2014, 01:02 PM
Pappa P's Avatar
Pappa P
Pappa P is offline
Hi Chip,
Thanks for the response. The grips have both an external harness to connect to the electrical caddy of the bike to supply voltage and an internal wire to connect to the right grip.
When I got home after having them installed I noticed that the trigger on the left switch housing, which is used to cycle through the odometer on the speedometer was sticking out a little further than normal, also, the switch housing, where the front and rear pieces come together was not meeting all the way, there was a gap, so I decided to investigate.
Old 11-17-2014, 05:39 PM
wwiiavfan's Avatar
wwiiavfan
wwiiavfan is offline
Received 1,115 Likes on 491 Posts
So it sounds like you weren't happy with the installation, not so much the grips themselves, right?
Who did the install? I'd be headed back to them to make it right.
By the way, doesn't the '15 Limited come with heated grips? My '14 did...
Old 11-17-2014, 07:41 PM
Pappa P's Avatar
Pappa P
Pappa P is offline
I am very particular about things, I guess it something I learned in the Navy, attention to detail. The guys at the dealership are really good and I appreciate all that they do, but, if I am going to pay the labor rate on a $30K motorcycle, they better get it to my liking. Yes, I will be taking it back to them to get it right.
Old 11-17-2014, 07:54 PM
J929626's Avatar
J929626
J929626 is offline
On my 2014 FLHTK, the left hand heated grip connects to the right hand heated in the middle of the bars (black / white connector). Heated grip power comes fro the fairing (red / black connector).
Old 11-17-2014, 08:15 PM
Pappa P's Avatar
Pappa P
Pappa P is offline
Do you have experience getting to the connectors? Removing the outer fairing is easy, the inner scares me! I do have the service manual.
Old 11-18-2014, 10:15 PM
Pappa P's Avatar
Pappa P
Pappa P is offline
Update. I was able to reconnect the left grip. I had to remove the aux lamps/turn signals, outer fairing, ignition switch, accessory panel and rotate the inner fairing. A service manual is a definite must! I was then able to locate the wire harness and feed it through past the end of the handle bar and reconnect the left grip. The entire procedure took less than an hour.
Drtumolo
2014-2023 Touring Models
05-06-2017 04:04 PM
trackerman
Electrical/Lighting/Alarm
02-01-2017 11:27 AM
YtseJam
11-02-2014 09:14 PM
Dynarider04
01-13-2012 06:58 AM
tincup64
03-27-2011 07:59 PM
Quick Reply: Slipstream Heated Grips.
