Wire Pin Terminal Size?
Old 11-01-2015, 10:00 AM
SnoRider's Avatar
SnoRider
SnoRider is offline
Default Wire Pin Terminal Size?
I have a 2011 FLHRC. I want to make up a wire for my passing lamps so they stay lit when high beam is on. I will remove the yellow wire pin from the passing lamp connector (white 4 pin connector that goes to passing lamp switch) and insert the pin on the wire I am making up. I will then route the new wire up to the orange with white stripe fender tip light wire that comes from the headlight and connect to it with a spade connector. I figure then I don't have to cut the original wiring.
Anyone know where I can get the pin terminal that is used on the yellow wire and what size it is? How about size of the spade? Does this all make sense?
Old 11-01-2015, 10:17 AM
sn95bullitt's Avatar
sn95bullitt
sn95bullitt is offline
Just snip the wires coming from the passing lamp and wire them together and plug it back in. The plug has 2 hot wires. 1 constant hot when you turn your passing lights on. 1 hot when the high beams are off.
Old 11-01-2015, 07:23 PM
SnoRider's Avatar
SnoRider
SnoRider is offline
Yeah, but with my method if all works out I don't have to do any snipping.
Old 11-02-2015, 01:56 AM
Bone Doc's Avatar
Bone Doc
Bone Doc is offline
Received 10,866 Likes on 4,113 Posts
In case you aren't aware, HD makes a wire harness to do just what you want; keep the passing lamps on with the high beam.
http://www.harley-davidson.com/store...11-69200442--1
It is only $30 and takes 5 minutes to install. I understand it would you cost much less to wire it yourself but $30 may be worth avoiding the hassle. Just an FYI.
Old 11-02-2015, 02:48 PM
SnoRider's Avatar
SnoRider
SnoRider is offline
Thanks Doc. Nice bike!
HarleyGTP
07-05-2016 02:58 PM
SnoRider
Electrical/Lighting/Alarm
11-02-2015 03:08 PM
matt76cmich
Audio Systems
11
08-30-2015 06:19 PM
Toliverpeterson
09-03-2012 11:07 AM
Man In Black
02-17-2010 08:44 PM
Quick Reply: Wire Pin Terminal Size?
