Remote wire help, no orange wire?
Old Aug 29, 2015 | 09:50 PM
matt76cmich's Avatar
matt76cmich
Default Remote wire help, no orange wire?
If i have over looked the orange wire on my headlight wire harness please forgive me lol. I am wondering if i will be able to use the blue power wire from what looks like an accessory plug on the left speaker pod (right side of looking from the front).
Also before i button everything up, the ground wire that was provided in the amp was short. I soldered the extra power wire to the ground. Should i just go get a ground so I don't have a soldered connection or will it be good to go?
Thank you, you guys have been very helpful.
Old Aug 29, 2015 | 10:18 PM
matt76cmich
These are the only wires I have found on the headlight wires, I could be missing something though.
Old Aug 29, 2015 | 10:26 PM
haze324's Avatar
haze324
I think the orange wire is only on the pre Rushmore. Gotta find some install pics and see where the newer bikes have been using a remote
BT site has install instructions posted under the support tab. Should be pointed out there.
Old Aug 30, 2015 | 07:11 AM
z71_fourwheelin's Avatar
z71_fourwheelin
You can tap into the Cig lighter red wire for your remote turn on. Also a solid ground wire is better. less resistance which could lead to static in the system.
Why did you cut off your head lamp connectors?
Old Aug 30, 2015 | 08:13 AM
matt76cmich
I have enough left over power cable to make a ground, I'll probably just do that.
Can i take a barrel connector and hook it up like the picture (be jealous of my art skills, haha)
Old Aug 30, 2015 | 09:17 AM
RDC434's Avatar
RDC434
I had a OEM hidden antena (POS) ! Anyway there is a power lead that it plugged into and thats what I used for the remote amp turn on.
This is on a 15RG.
Old Aug 30, 2015 | 09:25 AM
matt76cmich
I didn't cut em, just got a picture from Google.
Old Aug 30, 2015 | 09:40 AM
z71_fourwheelin
Whew... I was hoping that wasn't an "accident". Yeah that barrel idea is how I did mine and it works fine. I used this though
Old Aug 30, 2015 | 09:41 AM
z71_fourwheelin
This is on a 15RG.
Good deal... but where is this connector located so the OP can find it.
Old Aug 30, 2015 | 11:15 AM
RDC434's Avatar
RDC434
I don't have a picture. But looking from the front it was located mid top left side I think it was a two pin connector, don't remember the color wires, sorry.
If you find a open connector just use a test light to check it when power is turned on and off. Remember you want power on only for the remote on for the amp.
