Bolt torque help...
Old 02-25-2016, 05:31 PM
finespun automation llc's Avatar
finespun automation llc is offline
Default Bolt torque help...
Dragging my feet getting the service manual... Need a torque value for an Allen head cap screw on a side case.
I'm installing a new head pipe on my 2013 FLHTK. I removed the small exhaust bracket below the clutch release cover to clean and re-paint it.
Hoping someone can give me the torque values for the two bottom Allen heads that hold the bracket to the side case.
Thanks in advance guys!!
Old 02-25-2016, 06:10 PM
the warden's Avatar
the warden
the warden is offline
The manual does not specifically list these but the clutch relief cover bolts directly above them are listed at 132-156 in-lbs. I would suspect the bracket fasteners would be the same given they are the same size fastner.
Old 02-25-2016, 06:31 PM
Gliden's Avatar
Gliden
Gliden is offline
If it's the bolts that go thru the transmission cover holding the bottom exhaust bracket there was a service bulletin increasing the tq due to those botto 2 bolts loosening up and causing leaks. Whatever your reading in the manual ""up it" By 20 inch pounds.
Old 02-25-2016, 07:12 PM
Yep... those be the ones. Awesome info on the bulletin!
Thanks!
Old 02-25-2016, 07:38 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
the revised spec is 25 ft lbs.
for those who are trying to tighten these with the header is place, make a tool by cutting a piece off of a 1/4 allen key, or use a 1/4" screwdriver bit.
slip that into the head and turn with a wrench:
to figure out what 25 ft lbs feels like...torque the top bolts with a torque wrench to 24 ft lbs...use your tool to turn the bolt slightly...that's what it should feel like and apply same force to the lower bolts.
same tool can be used to adjust bar clamps
mike
Old 02-25-2016, 11:20 PM
the warden's Avatar
the warden
25 ft-lbs is a significant increase over 156 in-lbs. Where are you seeing that TQ spec.
Old 02-26-2016, 05:17 AM
skydude426's Avatar
skydude426
skydude426 is offline
I'm wondering the same thing. 25ft-lbs is the same as 300in-lbs. I don't think this can be right. I wouldn't torque those bolts that tight.
Old 02-26-2016, 05:40 AM
lp's Avatar
lp
lp is offline
Received 2,722 Likes on 1,547 Posts
It's laid out in bulletin M1305. 23-25 foot pounds.
File attached.
File Type: pdf
Old 02-26-2016, 07:53 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
hmmm, I see that lower spec referenced in the 2012 manual I have access to.
but my recollection for my 09 was 23 ft lbs.
this was revised to 25 ft lbs in about 2011 as the exhaust hanger vibrations were causing leaks
- I do remember that bulletin as many of the 2010 2/1 streetglides were spewking tranny lube on the ground...the lack of a tranny pan mount for crossover put more stress on the single mounting point- so the spec was revised going backwards
mike
Old 02-26-2016, 12:07 PM
skydude426's Avatar
skydude426
I wasn't aware of that spec change. Seems like a lot but if your careful it should be alright if that's what they suggest as a torque setting. I haven't had a leak yet with the 156 in-lbs, knock on wood.
Quick Reply: Bolt torque help...
