Replacing cartridge style forks???
Old 03-04-2016, 07:11 PM
Hades02's Avatar
Hades02
Hades02 is offline
Default Replacing cartridge style forks???
So 2002 - 2005 touring bikes (except Road King) come with a cartridge left side fork. Am ordering Progressive suspensions drop in lowering front kit to lower the front end after installing a 21 inch wheel. Is it as simple as removing the cartridge and dropping in the new springs? OR do I have to get a conventional left fork before installing the drop springs?
Old 03-04-2016, 07:28 PM
mike_oh's Avatar
mike_oh
mike_oh is offline
Drops right in. Everything you need is in the kit. You are going to upgrade both forks with the kit.
Old 03-05-2016, 03:02 PM
Hades02's Avatar
Hades02
Hades02 is offline
So for the left fork, use the spring compressor to remove the old spring off of the cartridge and install the new spring onto the cartridge. Is that correct?
Old 03-05-2016, 05:10 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Check Progressive's website, as they indicate that their kit will fit your bike. They also have a help line you can phone, plus an email address. I'm certain we used to be able to see the fitting instructions on their website. Found 'em! Look along the bottom of their website for Tech Info.
Hades02 (03-06-2016)
Old 03-06-2016, 07:31 AM
Hades02's Avatar
Hades02
Hades02 is offline
I did call them when I was ordering and they said you replace the unit. The instructions clearly state nothing needs to be done to the left side. You only replace the right side spring.
Hades02
02-08-2020 07:51 PM
Parts Giant
Parts Giant
04-17-2019 08:58 AM
bigpappa160
10-03-2018 09:11 PM
Dirty Fxstd
05-08-2012 07:34 AM
zombieroadking
03-01-2011 04:32 AM
Quick Reply: Replacing cartridge style forks???
