High flow air intake?
08-03-2016, 06:18 AM
Adding a vance and hines high air flow filter and intake to my 2012 street glide. Will I need to do anything else to it or just install and ride?
08-03-2016, 06:32 AM
If it's for looks, your fine. But to get any real performance you need it tuned somehow.
08-03-2016, 06:57 AM
08-03-2016, 07:09 AM
If you've done anything else to the exhaust, like change out the stock mufflers, most likely you'll need to retune the air/fuel.
08-03-2016, 07:56 AM
Ive changed the slip on mufflers.
08-03-2016, 09:13 AM
Does the Bike still have a catalytic converter in the header pipe ?
If yes most likely you will need a Tuner of some type, minimum XiED , or Fl-ViED-10
from Nightrider. If no Cat in header pipe then full on tuner will be needed, maybe one
with an Auto Tune.
08-03-2016, 01:25 PM
08-03-2016, 02:09 PM
Quote:
Originally Posted by
stbobshadow
no converter
Will probably run hot and give a bit of decel pop. You won't hurt anything if you don't beat on it. Best thing to do is get a tuner and be done.
08-03-2016, 02:41 PM
Ultraboy105
Agreed , good post.
Ultraboy105
Agreed , good post
BobRR
03-07-2019 03:51 PM
TALLY3
08-31-2013 03:52 PM
rherwerth
06-22-2010 12:15 PM
Ramez
04-12-2010 08:34 AM
TVil
Exhaust System Topics
09-09-2006 08:00 AM
