Trailering a flhuc
Old 02-06-2017, 02:43 PM
bassnman's Avatar
bassnman
bassnman is offline
Default Trailering a flhuc
I'm going to trailer my bike to Fla this month, what is the best way to disable the alarm on an 013 FLHTUC?
I understand it's all in the turn signals buttons..
Old 02-06-2017, 02:50 PM
chadk's Avatar
chadk
chadk is offline
i just left my FOB on the bike.
Old 02-06-2017, 02:51 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
if you have your owners manual, it's all in there.
if you don;t have a manual, post back and someone will type it out for you.
2.) do you know how to set and enter the PIN?
Mike
Old 02-06-2017, 03:21 PM
Mxdad's Avatar
Mxdad
Mxdad is offline
With fob present turn ignition switch to ignition
Before Security light goes out turn ignition switch to off
Press both turn signal switches. Both Turn signals flash at once
To get it out of transport mode just turn ignition switch on with fob present
That should be the same for your bike. That is word for word from the card that came in the owners manual of my 2017 RGU and is the same sequence for my 2008 FXDWG
Old 02-06-2017, 04:49 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
use the wallet card from the back of the owners manual.
Old 02-06-2017, 04:50 PM
bigdumbnoitall00
even with the fob present the alarm will still flash the lights on most bumps,unless the ignition switch is on.
Old 02-06-2017, 08:25 PM
groovna's Avatar
groovna
groovna is offline
I've just pulled out the main fuse during transport
Old 02-06-2017, 08:42 PM
CVO SG's Avatar
CVO SG
CVO SG is offline
"I don't always trailer my bike, but when I do, I put it in transport mode" Be safe my friend.
2ndtimeridr (02-07-2017)
Old 02-07-2017, 08:00 AM
HDJIM1158's Avatar
HDJIM1158
HDJIM1158 is offline
On my pre-Rushmore bikes I just put the FOB in the windshield bag and went on my way. Now with the Rushmore's I am told you have to put it in transport mode.... I heard a story that I guy trailered from New York to Florida with the FOB on the bike, but had a dead battery on arrival..... again, this is what I was told...don't know if true or not.... But I will be trailering this weekend in "transport mode"
Be Safe JIM
Old 02-07-2017, 09:23 AM
1HD1C's Avatar
1HD1C
1HD1C is offline
5 minutes to pull the MAXI fuse and 5 minutes to put it back and no having to remember to take it out of transport mode and then put it back in for trip home
Quick Reply: Trailering a flhuc
