Road Glide rear speakers
If anyone that has a RG and has added rear speakers off an Ultra and have them work correctly, can you give me some help PLEASE? I am frustrated with my dealer and I dont know what I need. What I have now is a tourpack off an Ultra with speaker pods, undermount amp and wiring to connect the amp and rear speakers together.
Thanks.
Thanks.
This is not what your are looking for but is an option for rear speakers with the ability to quick disconnect your tour pack. Look cool and are a no doubt a custom look
http://www.loudlids.com/
Thanks.
Thanks.
You can then use the dealer to sell you the connectors you will need to connect the wiring to the speakers and radio.
It'd be nice if you find someone who has your bike and done exactly what you want to do; but, in the meantime, you can handle this yourself--it's just simple wiring IF you have the wiring diagrams.
The alternative is to buy the overlay harness for Ultras that is sold for "add-on" HD rear speakers on Classics, Street Glides, and Road Glides and that will be over $100 IIRC.
Harleypingman,
I was hoping to find someone that had done this already and hope they chime in. I just bought the bike about 2 months ago and havent gotten a manual yet. That is my next step. I was hoping to have the speaker controls that are on the pods wired correctly so they would work for the passenger to use. If it wont or cant work, Ill just wire the speakers direct. Thanks for the input.
You should also check on the compatibility of your headunit with the speakers in the TP. The '06 and newer headunits are designed for 2 ohm speakers. Older headunits were 4 ohm, and even older ones for 8 ohm with the Ultra TP speakers on those units matching the headunits.
Good luck with your project. Let us know how it works out.
