EFI to carb
EFI to carb
Hey all. i just got a 1999 roadking. its EFI. i am very familiar with carbs and no EFI experience. what would i take to convert to carb. is the efi reliable? how does it compare to carbed bikes. thanx
It is a much more simple system than the delphi and in fact uses the same technology as older fuel injection systems in cars.
The system is also less affected by vacuum leaks.
Down side is very few younger techs have seen the system or understand it. Also if someone is going for a big build they could run into some fuel delivery issues.
The system is simple to maintain and parts are available..bulk of issues are: fuel lines(old), crank position sensor, cam position sensor...i believe 1999 specifically had a cam bearing issue that required replacement, fuel injector wire that was too tight and might of also had a bank angle sensor issue(bike would turn off over bumps/hard turns)..I would think that those issues would have been addressed already in the past 10+ years.
If you need more fuel for modest changes like aircleaner and pipes then consider J and P cycle and check the different piggy back fuel devices available.
M & M gets some bad press but i think it is because very few people are familiar with it and a limited number of tech have worked on them..Think about it, the system has been updated for about 10 years to Delphi...Younger techs. can probably work on a newer Delphi much more quickly and with greater knowledge than on a M & M or Carb.
Dude, just ride the bike and enjoy it. If it gives you a problem down the road, address it then. The M&M efi works just fine. The most common thing to happen with it is losing the idle settings once in a blue moon. It takes about 5 minutes to reset it when it happens. Go ride and have fun.
MM is fine IF you can get someone to tune it right. If yours is running fine now, leave it, don't fix it if it ain't broken. I had a 2001 ultra before. I gave up because I couldn't get the idle right and the ECU also had problem keeping the rpm constant while cruising.. Cost to fix my MM at the time was close to get carb conversion and I also want to do things myself, not relying on other people to get my bike right, so I want to convert it to something I am familiar with so I swapped mine to carb and I am VERY glad with the result.
Search on the net, tons of post on part number needed. Here is some tips from my experience (assuming your engine is 1999 twin cam, not last evo).
- Get daytona twin tech carb module (DTT TC88), you'll be glad you did, plenty on ebay and cheap.
- get the carb wiring harness WITHOUT the cam position sensor, will make it simpler, cam sensor is useless. Just cut off the cable close to the cam sensor head (inside the timer cover), leave the cam sensor head there.
- Buy the wiring harness from wireplus, better quality and it is labeled clearly.
- No need to buy MAP sensor, it is the same sensor from your EFI existing BARO sensor. Don't ask me how I know about this LOL !!
- Get Mikuni HSR42 for the carb, you'll be glad you did.
- Get fuel tank conversion plug for MM to carb from Pingel, and get their fuel petcock too. THE BEST...
- get wiring diagram from your model year and compare it with wiring diagram from 2002-2005. if you are only getting wiring diagram from your model year, you will be confused, because you are going to get rid of the cam position sensor. I have wiring diagram for 1999-2005, I can scan and send it to you if you wanna do this conversion. Email or PM me.
It a VERY easy procedure and can be done in 5-6 hours if you are familiar with your bike.
As for the result:
- I love the super instant throttle response. No EFI bike any year can compare with carb for this.
- I love the fact that I can fiddle with the setting without pushing some button that I dont know.
- I don't care if I got stuck with crappy gas, its carb.
- Carb gives the bike more badass idle sound.
Cheers
As for the result:
Cheers
king.felipe5
09-02-2012 09:00 PM
