Paul Yaffe or Fat Baggers Flush Mount Axle?
Old 12-30-2010, 11:44 PM
Beach Bagger's Avatar
Beach Bagger
Beach Bagger is offline
Default Paul Yaffe or Fat Baggers Flush Mount Axle?
I need some opinions on the selection of a flush mount axle. My 21"/18" wheels for my 2010 SG have been ordered from Eastern Performance and I also ordered a Fat Baggers flush mount axle and fork leg end cap, but I'm wondering if the Fat Baggers axle is the best choice. I like the way that the Fat Baggers flush mount axle looks once installed, but I've read that once it's installed don't plan on removing the axle cap from the left fork leg because it almost permanently wedges in to the left fork leg by design. The left axle cap blocks the bolt that has to be loosened to remove the left fork leg. My fork legs are already chromed, so I don't plan on needing to remove them unless I decide to lower the front end later, but I'm concerned that it would be a real pain to remove if I ever needed to. I'm thinking about changing my order and getting a Paul Yaffe flush mount axle instead. From what I've read the Yaffe axle is easy to remove when needed and nothing wedges into the fork legs. My only concern about the Yaffe axle is that it looks like from the pictures that I've seen that the attachment bolts on either side are not chromed and it may stand out more than the Fat Baggers axle. Any experience or opionions on these two axles or which one you would prefer and why?
Old 12-31-2010, 01:31 AM
Big Twi$t's Avatar
Big Twi$t
Big Twi$t is offline
I have the FBI axle and though I have not needed to take my front tire off since install of the axle, I'm sure it won't be that bad. The FBI comes with a bolt/washer that helps the left cap wedge on. Seems to me, if you want it off, just pop it off and use the bolt/washer to wedge it back on.
Old 12-31-2010, 01:39 PM
MLCrow1's Avatar
MLCrow1
MLCrow1 is offline
I bought the FBI axle from Eastern Performance and after 3 months hit a deer with my SG. I had no problems removing the front wheel, axle (both left and right) so I could get my forks re-chromed. As a prior poster said, there is a bolt that comes with the FBI kit to remove the left cap.
I don't know about the Yaffe one.
Old 12-31-2010, 05:08 PM
drewski1325's Avatar
drewski1325
drewski1325 is offline
I got a Yaffe flush axle. Boththe end bolts are chrome. Ya I didn't plan on removing my wheel either and I had an issue with a wheel which required removal. You may not plan on takin a wheel off but eventually you have to. I did see a thread this summer when I was debating the same thing that some guys had problems getting the KlockWerks and Fat Bagger axles out. Thus I went with the Yaffe. Glad I did. Might try doing a search for that thread.
harley_jeff
01-20-2018 04:50 AM
ridedaddy
01-12-2014 11:01 PM
chunks
04-08-2012 12:57 PM
bellgnte
12-09-2010 10:10 PM
rocknrod
10-13-2008 12:23 PM
Quick Reply: Paul Yaffe or Fat Baggers Flush Mount Axle?
