Flush Mount Axles Problems
Old Oct 12, 2008 | 10:37 PM
rocknrod's Avatar
rocknrod
Default Flush Mount Axles Problems
Well at least I dont feel pregnant. Im not the only one around that has had issues with a flush mounted axle:
https://www.hdforums.com/forum/showt...sh+axle&page=2
The threads on mine broke also.
Yes spacers are in the correct sides.
Threaded Cap wouldnt go in far enough to contact the axle threads.
Threaded Cap would not pull into the left side fork.
Threads broke on the axle. See floating brake thread for explaination.
Grease, anti seize, you name it. I used it.
Anyone know of a axle that actually works on a 08?
I need a new set
Old Oct 13, 2008 | 08:27 AM
rocknrod's Avatar
rocknrod
No ideas on who has these? No one has installed them?
Old Oct 13, 2008 | 11:21 AM
mikes300's Avatar
mikes300
Mine was just to tight for my liking, I polished the fork leg inside until I got what I felt was the proper clearance fit, then it pulled right it with no issues.
Mike
Old Oct 13, 2008 | 12:23 PM
rocknrod's Avatar
rocknrod
Ya the only way that left side cap could be pulled in on mine was to take a dremel sanding disk to the inside of the fork axle hole.
Not sure I should have to go there huh?
I did find a Paul Yaffe Bagger Nation flush mount axle. Its different in the way the axle cap is attached. I think I will use them.
ridedaddy
Jan 12, 2014 11:01 PM
Beach Bagger
Dec 31, 2010 05:08 PM
leeroynakd
Oct 5, 2010 07:31 PM
Chicago Spike
Apr 13, 2008 09:10 PM
Rev00
Dec 30, 2007 06:39 PM
