Dyno before break-in
Is it a good idea or a bad one to dyno a new bike rite outta the crate. New ultra is in and I'm going to do a stage 1 with kerker slip-ons and vance & hines power duals. Was told that I need the race tuner and a dyno because of the power duals. Which is fine! just wondering if I should ride it stock for a bit before I get it dyno'd. Thanks
Factory Dyno
When I took the York factory tour, as we neared the end of the line, we saw them take each bike and put it on a dyno. I watched the guy on the left push it past 100 mph and then off. The factory guy said that each bike gets checked before leaving the factory, and then some get a test ride also. His comment was if you get a new bike with some miles on it, it was one of the bikes that was pulled to ensure everything is ok.
Point trying to be made, is that the MOCO says to baby it for the first 500 miles, but they don't baby it with 0 miles, but not for very long.
I'd do the stage 1 and dyno after the breakin period. If for no other reason than if there is something "off" with the bike from the start, there is no added complication of the new parts, new tune, etc when it comes to diagnosing a problem. Its bone stock, so if there is a problem, nothing can be blamed on the upgrade. I dunno, just my thought.
Besides...when you finally get it on the dyno after 500 miles or so...you can get a before and after and see what your money bought you.
Check this out. To each his own I guess??
http://www.mototuneusa.com/break_in_secrets.htm
