Horn Relocation problem for LeNale Fan
ABS Equiped
I put my horn inside, covered by the right side cover. If you remove the right side cover, there is a plenty of room for the horn. I don't have ABS and I think this available space is where the ABS module would be if I had it. No heat issue in there and I like that the horn is hidden.
Down tube
When i was trying to install the horn on the down tubes, I still had the chrome cover on. Somewhere I read that maybe I should have removed the chrome cover from the horn when mounting it on the tubes. I didn't think to do that as it looks ugly exposed, but maybe I need to do it until I can find another horn or horn location. I did see one on the left side near the frame rail that looked ok. Keep the suggestions coming.
kpreese
12-16-2006 11:27 AM
accessory, cooling, davidson, fan, glide, harley, harleys, horn, install, instructions, lenale, motorcycle, problem, relocating, relocation, road
