oil capacity
Old 05-04-2012, 08:08 PM
pigbike's Avatar
pigbike
pigbike is offline
Default oil capacity
What is the oil capacity of a 2005 ultra classic which a filter change. The reason I ask is it's a trike and I can't put it on the kick stand to check it as per the manual.
Old 05-04-2012, 08:09 PM
dawg's Avatar
dawg
dawg is offline
Received 2,965 Likes on 1,715 Posts
Start out with 3.5 quarts and check accordingly. Actual says 4.0, 20-24oz in tranny (run at 22) and 1qt in primary.
Old 05-04-2012, 08:13 PM
RBWIDE's Avatar
RBWIDE
RBWIDE is offline
Harley didn't change the check oil procedure in the owners manual for the trike?? I'm having a hard time believing it says to check it while hot on the jiffy stand...wow.
nvsteve's Avatar
nvsteve
nvsteve is offline
Yup to what Dawg said. If you have an oil cooler add another half quart.
Old 05-05-2012, 08:07 AM
dawg's Avatar
dawg
dawg is offline
In 2005 HD didn't make trikes, they were all customized by other than HD so HD wouldn't have a manual for a trike. In the current HD triglide manuals you will find that there is an "upright gauge" on the dipstick. See attached.
Old 05-05-2012, 08:12 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,524 Likes on 1,421 Posts
Dawg is right on.
OP, sounds like you need the HD Forums free app for your smartphone, lists capacities and other useful info. Check it out.
3.5 qts. works for me in my '11 RKC. Try it, check, ride, check.
Old 05-05-2012, 08:40 AM
threeten's Avatar
threeten
threeten is offline
Originally Posted by TheGrandPoohBah
Dawg is right on.
Great idea.
Old 05-05-2012, 08:57 AM
RBWIDE's Avatar
RBWIDE
RBWIDE is offline
My bad for not noticing the OP specified a 2005!
Old 06-19-2012, 11:18 AM
2WheelThrill's Avatar
2WheelThrill
2WheelThrill is offline
...sounds like you need the HD Forums free app for your smartphone, lists capacities and other useful info. Check it out..
Where can this be found?
msengel
06-25-2018 02:27 AM
Doc o
10-19-2010 03:12 PM
jimski
11-04-2009 06:51 PM
Meinbmw
12-15-2005 12:44 PM
Jezcruzen
Oil Archive (no new posts)
08-08-2005 12:33 PM
Quick Reply: oil capacity
